My 32 is painted gold (bought like that) and it looks like a good paint job, other than they didn't tape it up very good. (A lot of spray) Whoever looked after the paintwork did a really bad job... If it ever was looked after. I'm using it as my test to cut & polish, but will be going through a couple of YouTube vids so I'm not completely hopeless. I'll chuck some before & after pics WHEN I do the deed. Only doing this because I will be getting a respray in the future.. Still tossing up between a darker gold or white..
Unfortunately this happens a lot where people just take a cut and polish to fix any paint issue and it ends up ruining your paint. Hope all goes well because sometimes a cut and polish is a must and seal with wax. If you get to that stage expect to wax it every 2 weeks or so.
Haha, yeah.. I'm pretty sure I will end up making it look worse :P
But, half of the paint has already been ground away to get rid of the rust :D
The issue with most detailing places is the firs thing they do is take a mild cut and polish to your car. RUINS your paint.
...or I recommend taking the time out and doing it yourself.
My detailer has a "Paint Thickness Gauge" which tells several stories - before even touching the car.
* How much paint he has to work with - or with the N1, not to work with.
* With sun damaged panels (horizontal ones), more latitude can be had with cut 'n polish within certain micron tolerances
* Panels which have been repainted will give off thicker readings
* Nicki (- sounds better than bog) can be detected in vulnerable spots
If you don't mind giving a ballpark figure, how much does it cost for someone to give the car that much attention to detail etc? Just curious really.
Eugene Chan charged me $400 (mates rates) for the two day weekend Jeremy.
Typical process was...
Wash > Clay Bar using Lubricant > Polish (Menzerna brand) 2x with different grade pads > Sealant (Optima brand) applied > Cure overnight > Wax (Meguiar's or Menzerna brand) > Buff
Eugene (aka JDM_Performance here on SAU) learned from Polich Doc in Melbourne. Eugene detailed my 3x R34 GT-Rs
#1 R34 GT-R Black won the Concours Skaife award at the R34 GT-R 10th Anniv
#2 R34 GT-R Bayside Blue (above) wasn't owned for very long before being forced to choose, upon the availability of an N1 - paint thickness on every panel was about 320 microns
#3 R34 GT-R White N1 in PI Magazine #161 - paint thickness on every panel was consistently about 90 microns
Yup, very happy with Eugene - but pretty far away from you guys I'm afraid.
  • Like 1
Yes it's impressive.
It won't work unless the panel is made of metal.
C/F, Nicki or rust with give lousy readings.
The Detailer has to love what he does - with a passion!
Eugene has that passion - yet he hates gardening.
I love gardening - but but hate detailing unless I'm totally in the mood and begin by 7am , Lol
Thanks for the info Terry. Amazing job done on an amazing car. It's almost worth driving down to Sydney and then glad wrapping it for the trip home haha :P
If you let him detail your N1, then Eugene must be good.
Cheers for sharing.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
