Hey fellas,
Got a hold of a hoist recently (best thing ever might i add), but just wondering where the hell do i put the arms under on the R33?
The rails look pretty soft...so just thought I'd ask this silly question before i go and stuff something up!
https://www.sau.com.au/forums/topic/433335-hoist-spots-for-lifting-r33-gtr/
I use the stock jacking points, don't use the chassis rail inboard of it, they are way too soft.
Took my car to a mechanic about a year ago and he somehow caved in my jack points :(
Ps: totally random comment, but I just felt the urge to mention it :P... Lol
Slightly OT but if using a trolley jack, I've always used front sub-frame/rear diff. Is that generally considered the right place to use? I've heard people say use chassis rails, but as stated above, they seem pretty soft.
Never on those "chassis rails"! Unless you want a very expensive repair bill to fix them, they are soft and not for loading on at all :no: . There are axle stand points on the sills front and rear I believe, also some hoists appear to have additional inboard blocks to lift up the chassis on the diff/subframe area though I'll assume you have a 2 post hoist with the adjustable arms so the sill points will be the go with appropriate soft blocks/pads. Again don't use the "chassis rails" as this is at least a $500 repair if you get caught with the damage.
Hope that helps!
Links;
http://www.skylinesaustralia.com/forums/topic/266324-howwhere-to-lift-a-skyline-r33s2/
http://www.skylinesaustralia.com/forums/topic/118956-jack-stand-points-needed/
^Side member=NO LIFT NO! ;)
Thanks for all the reply's fellas, Havn't had a change to throw it up on my lift yet, but was happy i remembered reading somewhere "Don't lift on the chassis rails" ha ha as my old man told me to put it on there!!
When you say the jacking points ( I have never used them on the skyline, I always used to jack from the cross member up front and the diff on the rear), are you refering to the metal tab/cut out looking things just after the front wheels near my side skirts? There are also some just in front of the rear wheels too.
I have uploaded a picture of my hoist pad, as it is all still pretty new to me!
And yes - It's a 2 post hoist where the arms are of adjustable length
Also - What are sill adapters?
Edited by Booki
The jacking points will be on the sills (just in from the side skirts).
Pretty sure there meant for emergency jacking only but for a hoist there really the only place you can use.
And that pic you have is basically what every hoist should have anyways, they should all have rubber pads.
I took a few snaps - i assume these are the sills, and like everyone else. Mine look like they have been damaged....so don't know if they are safe to lift on? I don't want to wreck them more :\
Can you lift from this point on the suspension?
I have circled the area, although that only covers the rear....anywhere else i can go from the front?
Those are the right points, they're standard locations on most cars Ive worked on. Behind the front wheels and infront of the rear wheels. And yeah don't jack up on the chassis rail.
Good to see in that pic up there Booki that your jacking points are still in good shape, both my cars are flats because the wrong jack was used. I now lift from the rear under the diff and the front, where ever I see fit.
The load point is the flat section between the two half circle cut outs, if you look at the factory jack it has a cut out in it which is to allow the bit that sticks down to go into, so the concept is the same for the hoist, make sure the bit that sticks down goes into a cut out
NEVER lift from the chassis rails
Is there anywhere else you can lift the car up from? (Using a 2 post hoist)
Can't grasp the concept that the little bit of metal sticking out where you put your emergency jack is where you lift the car from, maybe I am looking at the wrong thing.
How do peoples get damaged if hoist pads have cutouts in them?
Edited by Booki
  • Like 2
They don't if you lift the car level, with all 4 pads on the correct spot. The jacking points on the sill are reinforced to handle it, just take it easy and make sure the pads are central as you lift.
  • Like 1
hijackin the thread - but is it possible to get my jack points repaired? they are completely screwed up... :(
A little heat a large flat blade screwdriver and a shifter should have most of it bent back, depending how it has folded, but it will have limited strength afterward
I find they crush when most of the car's weight is put on to one point. That's why a trolley jack on the front point works fine, as do hoists when balanced properly.
Alrighty!
Actually got off my ass and had a good squizz at the car.
As you guys have said, you can tell where the lift points are and how it works after looking at it with the pad under neath it (and comparing to the factory jack lol).
But....the pads I have are not deep enough to totally prevent sill damage, it will hit the sill when i lift.
anybody know of any other type of hoist pads or adapters i can use to be 100% safe not to damage the sills? (Yes im fussy like that :P )
The genuine nissan one is LM4086-0200
Havn't been able to find it online yet
Edited by Booki
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
