Bang for buck, Unitig AC/DC 200 amp. You will need to buy a foot pedal for it though, and 15A GPO.
I have used one daily for about 5 years, good unit. Only once did it let me down, a circuit board blew out, but the replacement part was on the shelf in Sydney. I just can't justify buying a Miller for 5k when this one does a similar job for 1/4 the price.
  • 1 month later...
I have the same unitig as scotty, had it about a year now with no issues except for the gas reg that comes with it was leaking slighlty but they swapped it over for me on the spot. i got my sparky mate to install a 15 amp power point as is required for any high amperage equipment. to run the 15 amp line and power point cost me about 150 dollars. I havn't had to push 200 amos through it yet however i have put together some mild steel at about 140 amps for about 2 hours and it seemd fine, no noticable increase in temp of the machine etc. if your a beginer, then dont let all the knobs scare you, once you read uup about them you can adjust them to what ecer you need. most are simple stuff like post gas flow time etc which are not critical to typical jobs however help to finish up welds. youll get it after a short time. many years ago i used a large and expensive cig weld machine when i did nascars and in all seriousness the only difference i care to mention is the size and weight of these new inverter technology units. i have it mounted on the wall just above a bench and mostly use ot to do my own exhausts and cooler piping etc. It seemed to be the best value for money at the time.
A few times, 6 track days I think. The auto box doesn't like it much. :/
yeah gotta get a manual in there!
Would there be any stores that stock uni tig 200s in in sydney?
been to the track much scotty?
im in melbourne and i got mine from a mob called united tools
try this, http://www.unitedtools.com.au/new-south-wales/
Silverwater welding supplies have them also total tools (who had a big sale recently and u could have saved a bit) and also Hare and Fobes (also had a sale on).
I purchased a cigweld acdc machine when total tools had 30% off everything in store a while ago and have found it to be a good machine. Cost me a little less then what the normal price of the unimig machine was going for.
  • 3 weeks later...
It still has the same model number - search Smootharc Advance MIG 200C (for some reason SAU won't let me paste links, or even copy / paste into my posts :domokun:). Not sure whether they've changed the internals - for that kind of price rise, I'd hope so. Mine was on special when I bought it. I paid $750, and it's currently advertised at $1160-ish. I've seen them advertised for over $1200.
Top unit though (for a MIG). It turns ordinary welders like me into freakin geniuses.
I did a course a while ago and we were able to use the new lincon welders. It was able to automatically adjust wire speed and amps to the metal thickness. Bloody amazing machine and made u look like a pro. They were into the thousands though and more for large shops I think.
Not the token tools one however when researching for my machine I narrowed it down to the unimig machines and the cigweld. Silverwater Welding highly recommend the Unimig machine and have had very little trouble with them. I only bought the cigweld machine because of the deal I got.
I just bought a token tools Alupulse 200D Deano, haven't had much time to weld, but the stuff i have done has come out great (and i haven't TIG welded for 25 years). Got the pedal with it but haven't used it yet but everything else is quality.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
