Hi guys,
My r33 gtst has recently started intermittently overheating.
It is completely random. Sometimes, it can drive for days being fine whilst other times it will overheat immediately.
when it does start to overheat I can stop the car, let it cool down and then its fine to go again without overheating.
Only appears to lose water when it overheats and comes out the reserve.
I've tried another thermostat..... still the same. Any ideas?
https://www.sau.com.au/forums/topic/433670-r33-overheating/
Never had this problem myself in a skyline, but my run around (shitbox) honda integra used to have that problem - turns out there was an electrical issue in which the fan would randomly (& intermittently) stop working.
Good luck with it :)
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7071727
Is it just random, even at low speed?
Do you still have the original radiator?
It is getting old so I'd say replace the radiator.
Mine would start to overheat when driven at 100km/hr. Went through the steps and once radiator was replaced all good.
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7071838
Thanks for the replies!
So far:
New Thermostat hasnt changed anything
New radiator cap hasnt changed anything
The electrical fan appears to be working
Not the original Radiator - It got replaced a few years ago
I happens randomly so Its got me stumped :(
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7072130
thanks for the replies.
All work done professionally by a mechanic (not me!) so quite a few things checked.
Thermostat is genuine Nissan.
All (or if not most!!) hoses have been replaced
Yes still has the standard clutch fan
I've never done a water pump in it
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7072396
O.K. How many km has the engine done?
Highly doubt its the water pump, especially if the teltale isnt leaking but have to ask anyway
Does it need coolant ever?
Have you measured the temperature with a temp gun or something like that? Just in case the sensor is a bit funny and giving false readings
Edited by 89CAL
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7073160
Not to hijack the thread, but I've had overheating issues lately too..
When I'm on the move, the car is fine, but when I'm stopped, that's when it can overheat (and the temp jumps up pretty quickly)... And it happens randomly too!!
Found a whole lot of shit in the radiator fluid and overflow bottle, so I had the radiator completely flushed and the fluid replaced... Any thoughts??
I'm thinking maybe water pump, hoses or fan.. Anyone have any similar issues that can give some advise/insight??
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7075630
If its overheating when its stopped and not overheating when its moving, then wouldnt the logical problem be the radiator fan? Seen as you have had the radiator serviced this is pretty much all it can be. The fan doesnt do alot when the car is moving, when the car is stopped the airflow accross the radiator is created by the fan
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7075643
Yeh I know, and that's what I thought.. When I took it to my mechanic a second time to check it out with me, it was fine.. One of those "does it when no one is around, and doesn't do it when u want it to" kind of things...
Just thought I'd post up incase it could be something else.. Probably best thing is to just sort out the fan regardless..?
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7080439
Well if you haven't done the radiator in recent years take it out and get the top taken off and either clean it out or get a new one if necessary. If its getting blocked it will still work better with a 100km breeze going through it than when stationary.
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7080574
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
