Hey Guys,
After another enjoyable day at WTAC, and hearing the gibson motorsport cars, can anyone explain to me why the HR31 sounds absolutly mental?
Is it all in the exhaust? (or lack of)
Looking in the bay obviously it has the GTS-R exhaust mani, but still has an internally gated turbo.
The note is different to pretty much any RB i've ever heard.
Could it be its maybe revving harder?
https://www.sau.com.au/forums/topic/433757-gibson-hr31/
Yeah someone on the R31 Skyline club had a replica made. Can't remember who. Pretty much just get someone to make the longest equal length runners that will fit in the engine bay.
Yes the car is a GTS-R but the manifolds were made by Gibson (slightly different to GTS-R, sound is pretty much the same I believe). If you were to throw a GTS-R manifold on your RB, it would sound pretty much the same.
https://www.sau.com.au/forums/topic/433757-gibson-hr31/#findComment-7073840
Why does it have a circular opening in the flange to the turbo ? Seems odd?
Also, the fact that the GTS-R and Gibson manifolds are tube not pipe, means the resonance from them will be different. If you want MAX banshee than tubular manifold will be the pick. not one out of pipe bends
https://www.sau.com.au/forums/topic/433757-gibson-hr31/#findComment-7074013
Didn't the GRP A regs state that the exhaust manifold had to remain standard from the head to the first join? Hence the VL Walky had individual exhaust runners about 3-4"long from the head, after which the exhaust was free.
If that's the case, how would Gibson have homologated this manifold? Or did turbo engines have a different set of rules?
https://www.sau.com.au/forums/topic/433757-gibson-hr31/#findComment-7074058
They put the one they made in a Nissan box and showed the scrutineers. Not like any one knew what the cars had back in Japan anyway.
https://www.sau.com.au/forums/topic/433757-gibson-hr31/#findComment-7074131
  • 3 weeks later...
And make a 4 inch side pipe as well.
Was amazing watching Skaife race one eariler in the year at PI Historics.
Coming out of the final turn and flat shifting down the straight... eargasm!
Sure was a great day.
You can't compare the Gibson to any other manifold, it is made from a special material with sand bent one piece runners. I can try and get some manifold pics next year at PI if you like, all the Gibson cars are together in the pits.
https://www.sau.com.au/forums/topic/433757-gibson-hr31/#findComment-7111241
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
