Good afternoon all,
i need money for tires so the shed need to get a clean out.
i have priced everything at $200 for ease and to move the parts.
located in Andrews Farm and work in Thebarton so pick up from either,
i can post anything at extra cost but not much more so please feel free to ask.
ok.... please buy the following...
R34GTT rear bumper
white and in excellent condition however i would recommend a repaint, no cracks or dents ect
bought for a car i no longer own
R34 aftermarket front bar
fiberglass with vents both sides. painted black, some scrapes and marks mostly on the underside where it is not visable. larger opening and shallow cut for FMIC
C34 SII SR4 Stagea front bar
Pearl white
condition is good, some scrapes but in good condition without damage.
this has been replaced by a days bar on my stag
RB25DET NEO genuine coilpacks
one is weak and caused a misfire.
selling the full set of 6 but only expect to use 5
i dont know which one was missing,
great for replacing one or a few faulty packs on your R34 or C34 NEO
RB26DET R32 GTR coilpacks
excellent condition genuine items
no missfires very minimal Kms, these were replaced with splitfires which felt no better to the genuine items.
can be used on RB20s as a good upgrade as i did on my 32
R34 GTR dash
unknown KMS but i have been told it should read about 28000km from the previous expected owner
awesome condition, cannot fault.
can be used in a GTT,
great for manual conversion
pleas feel free to ask question or for more photos.
i can post anywher ein aust easily and cheaply no matter the size
PM or txt
0413 145 430
Glyn.
https://www.sau.com.au/forums/topic/434573-the-200-thread-r34-r32-c34-bits/
So keen on that front bar !!!! :x
It's a bolt on front bar correct? (It doesn't need to be chopped or changed?)
Edited by RosieR34
as far as i know it should go on with no dramas using stock mounting holes.
im 99% sure the prev owner removed it from his R34, i was going to fit it to mine but the car sold first.
Edited by GH05T
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
