So When do we start seeing cars, who will be the first to unveil their 2014 machine?
I dare say they will be keeping them under wraps as long as possible seen as there are yet another lot of major rule changes.
Think I'll go searching for launch dates now :)
Actually no, it isnt. You specify a minimum cockpit dimension. You specify a minimum weight for the driver eg 90kg. You then specify the locations for the make up ballast that the jockeys carry. Job done.
Yeah I get that but say you place remaining weight/ballast nice and high to discourage jockeys you can potentially disadvantage lighter drivers. But I bet Montoya agrees with you.
Well there will always be an argument at the margin. But surely it cant be beyond someones ability to work out the cog of a sitting driver and put it about there in the sides of the cockpit. Would surely be less than the difference between having a driver with a massive jawline compared to a pin head. So DC vs ???
I think the two of you just showed why you are not competent enough to run F1. You never start negotiations by dropping your asking price. You start by promising value added performance derived from their 400k investment, not devaluing yourself. 400k is already a couple of billion dollar saving :)
Seems NJ GP is about as likely as the USGP F1 team that Windsor was behind a few years ago. Another delay and another 19 race calendar. Should be going back to India for a 20 race calendar
2014 CALENDAR
March 16 Australia
March 30 Malaysia
April 6 Bahrain
April 20 China
May 11 Spain
May 25 Monaco
June 8 Canada
June 22 Austria
July 6 Great Britain
July 20 Germany (Hockenheim)
July 27 Hungary
August 24 Belgium
September 7 Italy
September 21 Singapore
October 5 Japan
October 12 Russia
November 2 USA
November 9 Brazil
November 23 Abu Dhabi
http://www.planetf1.com/driver/3213/9057152/F1-season-finalised-for-2014
abu dhabi is the last race.. :(
2014 CALENDAR
March 16 Australia
March 30 Malaysia
April 6 Bahrain
April 20 China
May 11 Spain
May 25 Monaco
June 8 Canada
June 22 Austria
July 27 Hungary
August 24 Belgium
September 7 Italy
October 5 Japan
October 12 Russia
November 2 USA
November 9 Brazil
2014 CALENDAR
IM ALRIGHT WITH THIS BECAUSE IF THE TITLE GOES DOWN TO THE FINAL ROUND... WHICH I WONT... AT LEAST ITS NOT IN A TIMEZONE THAT IS HORRIFIC FOR ME TO HAVE WAKE UP IN
SORRY FOR CAPS... FCUK IT, IM NOT RETYPING IT NOW
Rumour has it MB were the team who voted no...
TRAINING will continue in earnest for Australia's Daniel Ricciardo, who has been told to shed a couple more kilos ahead of next year's Formula 1 season.
He is one of several already-thin drivers having to lose more weight thanks to the sport's new technical regulations, set to be introduced next year.
This year's V8 engines will be replaced by turbocharged V6 units, heavier than their predecessors thanks to the added hardware needed by the new motors.
However, that reduces the margin for the driver under the sport's minimum weight regulations, which take into account both the car and its pilot.
Ricciardo, one of the taller drivers in the F1 field at 1.75 metres, tips the scales in the mid-60 kilogram range.
But he will be looking to edge that down to the low-60s by the time testing of Red Bull's new RB10 begins in January.
"Compared to where I am now, I need to lose a couple more kilos," Ricciardo told Brazil's Totalrace. "That's my goal."
The issue of driver weight has become increasingly contentious, with taller drivers having to stay ultra-lean in pursuit of extra speed: every five extra kilograms costs a driver roughly 0.2 seconds per lap.
"Haven't eaten for last 5 years! Minimum weight has been too low for ages," the now-retired Mark Webber tweeted earlier this season.
Webber, whom Ricciardo replaces at Red Bull, stands at 1.83m and weighs in at 75 kilograms.
With the muscle drivers need to withstand the strain of driving an F1 car for up to two hours at a time taking up a lot of their weight, that doesn't leave room for much else.
Several F1 teams are currently pushing for the minimum weight of car and driver to be increased by 10kg to 700 for 2015.
"I think it should be changed," Red Bull's technical guru Adrian Newey told Autosport.
"All teams bar one did vote for that weight limit to be increased and it has to be unanimous - but there was one team that objected to it."
The topic is set to be a hotly debated subject at the F1 Strategy Group meeting next week, where the teams discuss their thoughts on the future direction of the sport.
For his part, Ricciardo doesn't expect losing the weight to be difficult, citing the competitors in his other favourite sport as inspiration.
"It's not a problem. I like watching UFC (ultimate fighting championship) and those guys lose eight kilos in a week or something when it gets close to the fight.
"Two kilos in four months will be easy."
Ricciardo is set to make his first official appearance as a Red Bull driver when he gives their show car a spin in Sri Lanka next week.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
