Sounds like a Monty Python reference
Farken wont let me link or embed videos (can't even copy / paste URLS in here) farken
Look up 1967 Formula 1 German Grand Prix (2 of 4) on youtube - by thash1127. Fast forward to 0.59 and watch the next 5 sec. As they round the second right hander, you can recognise the rise just behind the 2 cars in the photo above. I'm convinced it's Brunnchen at the Nurburgring (recognised it from my hundreds of hours driving the 1967 track in GPL) :whistling:
Can't wait till they start the season (or maybe get a bit of the way through) and start revealing more details about the engine + Energy systems
too bad we don't get sky here..
Formula 1 will award double points for its final round from the 2014 season in an effort to keep championship battles open longer.
The move was agreed by the F1 Strategy Group and the Formula One Commission at a meeting in Paris on Monday.
http://www.autosport.com/news/report.php/id/111795
Permanent driver numbers will become a reality from the 2014 Formula 1 world championship, the FIA has confirmed.
While #1 will be reserved for the current world champion - should he choose to use it - every other driver will be asked to choose their race number, between #2 and #99.
http://www.autosport.com/news/report.php/id/111796
A budget cap will be introduced in Formula 1 from the start of 2015.
The move was agreed at a meeting of the F1 Strategy Group and the F1 Commission in Paris today.
A working group will be established to finalise the regulations governing the cost-cap regulations.
This group, which will include representatives of the FIA and of the commercial rights holder, as well as F1 team members, will be tasked to finalise these regulations by the end of June 2014.
It is not clear how the budget cap will be structured, although previous proposals have included exemptions for marketing and driver wages.
http://www.autosport.com/news/report.php/id/111798
Guessing 1937? NFI where.
Was tempted to say real men like the unfortunately named Englishman who drive for Mercedes in 1939. But I wont because that would be wrong as he ended up dead at the Belgian GP that year.
It's the 38 German GP and Dick Seaman actually won it..
I know! It's the one thing stopping me from running out and getting Foxtel. Would be great, but its something to do with the deal channel 10 have atm I think isnt it? When does that dry up? :P
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
