Lotus have revealed they have a 114m (pound i think) debt and the quantum deal has fallen through. They say everything is all good because of Faildonados money.
Don't really understand why no major sponsors wanted in on Lotus midway through last year, I can see why it doesnt seem so good now however. Might be downhill for Lotus unless Grosjean can keep them alive.
Bernie Ecclestone will step down as a director of Formula 1's management board, but he will continue running the sport.
German prosecutors announced on Thursday that Ecclestone will face a court hearing in Munich at the end of April to answer claims that he bribed German banker Gerhard Gribkowsky over the sale of F1 in 2006.
Although Formula 1's owners CVC are allowing Ecclestone to continue his day-to-day running of grand prix racing, a statement issued by Delta Topco Ltd stated that it has agreed in a board meeting on Thursday that he will step off the board.
"After discussions with the board, Mr Ecclestone has proposed and the board agreed that until the case has been concluded, he will step down as a director with immediate effect, thereby relinquishing his board duties and responsibilities until the case has been resolved," said the statement.
"The board believes that it is in the best interests of both the F1 business and the sport that Mr Ecclestone should continue to run the business on a day-to-day basis, but subject to increased monitoring and control by the board. Mr Ecclestone has agreed to these arrangements."
Ecclestone has routinely denied any wrongdoing over a payment he made to Gribkowsky, and reiterated his claims of innocence to the board in Thursday's meeting.
The statement added: "Mr Ecclestone has reassured the board that he is innocent of the charges and intends to vigorously defend the case which will commence in late April 2014."
Ecclestone's stepping down from the board means other senior management figures will now take a more direct role in the future direction of F1.
The statement added: "The approval and signing of significant contracts and other material business arrangements shall now be the responsibility of the Chairman, Mr Peter Brabeck-Letmathe, and Deputy Chairman, Mr Donald Mackenzie."
http://www.autosport.com/news/report.php/id/112156
Dennis was always a wanker. Sorry, what he did to DC and Montoya annoys the hell out of me. He got results in the 80s with Senna and Prost. He got results in the 90-00s due to Newey. Newey in part left because of what a miserable place Dennis made it.
So, lol yep, come on back Dennis.. I look forward to going back to hating McLaren rather than feeling sorry for them! And look forward to watching the messiah come back for all to realise that he is just a guy that was smart oenough to know he needed smarter more talented people around him.
  • Like 1
speaking of graves...
schui not doing too well
coma till he is dead.
His condition has been described as stable now
anyone seen this yet?
i like the sound of the turbo spool :)
http://www.youtube.com/watch?v=pXNLQQC_AGU
If they sound like this, I will be able to live with it :)
That could also be for Le Mans? Going up against webber and his Porsche?
Ron might have been a flamin mongrel but witmarsh has been a joke lol. I hope brawn down tend up back at mclaren, lauda was stupid to get rid of him but no surprise as he thinks he knows everything.
Rush was an ok watch if anyone hasn't seen it
Niki did the same thing to Bobby Rahal at Jaguar, came in as a consultant, told the Ford board that everything was being done wrong (even thought Rahal had managed to get Newey on board) ended up taking over the place and screwing it up.
Yeah I heard he has a track record of f**king things up, which is a shame. I'm looking forward to trying these new cars on f1 2014, hopefully it's on ps4.
Not long will we see these cars hit the track for testing :) I hope there is a few engines that blow in spectacular fashion there hasn't been nearly enough off that in recent years
  • Like 1
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
