I dunno. I always assumed it was a control fuel like the v8 supercars run, but they were saying at the start of q1 that the fuel supplier to redbull are expecting to gain 1/10th of a second from their new blend.
Whatever they have been using has been damaging the nearly infallible fuel flow sensors.
Maldonado Says Crash wasn't his fault
I can't believe sponsors still want to put their name to him. And I think he could have saved it if he hadn't locked up just before he hit the wall. Car looked like it was about to swing back
Anyway, great to see Dan up there again. Not so great to see that Mercedes are 1 second ahead of everyone. It's hard to believe that they are so far ahead, surely it can't all be engine?
It shows how much better a driver Grosjean is then Maldonado, seen as they were put in the same basket a few years ago
I think Maldonado annoys me so much because he constantly screws up then blames everyone/everything but himself, when alot of the problems seem like rookie errors
The issue now is that its a good thing he has bought money to Lotus now. But I'm worried for what will happen to the team when he decides they must be against him like Williams were because he isn't winning races, and by then Lotus may have lost alot of potential sponsors because of Maldonado. I don't want Lotus to fail
Romain had a cracker! Had problems all race but still grabbed a solid 8th. Was good for a 5th olr 6th if the think ran on all 6 cylinders for the whole GP.
So RBR is clear no.2...from there its l;ooking rather close between Fezz and Williams with Force India and Lotus sticking their noses in from time to time.
LOL, all hail King Dennis...he is doing a stella job at McLaren!!!! :)
I dont think the Lotus has the speed to defend down the straights problems or not at the moment sadly
If you looked at the Lotus during the early and closing laps it had the lap speed to keep the Williams honest and Fezz behind....problem was they had an instrument problem that cut power for periods of the race and at times was only running on 5 cylinders :(
Keen to see how Romain goes at Monaco...god knows he over drove last year and had a shocker
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
