So i watch and shake head. Nico jumping around celbrating(not after stunning lap) after causing a yellow, Lewis sulking. But I watch F1 for driving entertainment, not finishing school etiquette. Thank god Mercedes pair are racing - this is entertaining. I know who I want to win tonight, the driver, not a professor (Prost like accumulator) :-)
If you want to see driving entertainment watch the GP2 Race 1 :)
Cars tag each other into the hairpin and spin around blocking the track, suddenly 20 cars are all trying to find there own way through resulting in the race red flagged. Marshals everywhere, crane trying to fix the situation. Then they cant get the cars restarted (push start) because they are too hot from sitting idling so marshals push them all the way around to the downhill exit of the tunnel. Quite hilarious!
I don't even bother waiting for the podium interviews...
Lewis couldn't see through the tears at the end. Was hoping Dan would snatch 2nd off him...
Kimi was bloody unlucky, but good to see him get his mojo back in the car.
Dan continues to impress. Kept an extremely cool head catching and looking for a way around Hamilton. I think if he can stay in a fast car he has a bright future
Flicking through some news articles at the moment and looks like Hamilton is trying to screw up his Mercedes drive, saying McLaren would have pitted him as soon as sutil crashed if he were still racing for them, and also saying that NIco and himself are not friends. He obviously doesn't think before he talks
Kimi on for a good race till that puncture, really went downhill from there
Fantastic finish for the race last night. Pity the Mercs are so much quicker on the straights. The only place to overtake on the track and Hamilton could re gain a gap at it. Dan should have been second. But that's how the cookie crumbles!
In saying that i feel for Hamilton. Everything was not going his way. He deserved better.
also message to vettel: HAHAHAHAHAHAHAHAHAHAHAHAHAAHAHAHAHAHAHAHAHAHAHAHAHA that's what you get.
P.S i hate Vettel.
Inb4 Daniel gets his podium taken because his beard wasn't to regulation or some shit.
Homo is lucky there is no well credentialled German who appears to be disenchanted with his team floating about and who could easilly take his spot.
Oh, wait.
Hamilton is either doing this because he is a complete douche bag or he is getting some very, very poor advice. Interesting to see what happening in Spain with him turning up his engine. Note that it came out of the team, not out of Rosbergs mouth.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
