So Mark has signed on with Ch 10 for next years commentary team. Hopefully this means that hack Jones gets the boot, as jones doesn't like MW from previous comments....
Awesome!
Mark hasn't been out of the game long so his insight will be more up to date then jones.
sweet.
No disrespect to Jones, but it will be good to get some fresh blood as commentary with One/Ten
https://mobile.twitter.com/andersonlaura12/status/502456603845861376/photo/1
Caterham have a new nose to go with their new driver.
and they'll now have 2 drivers fighting each other to be slowest on the grid.
bringing in a 32yo never-has-been who couldn't make the F1 cut 12 years ago, Sportcar Endurance journey-man to try and help develop your F1 car at the expense of the fastest driver your team's ever had, and probably ever will have, is retarded.
/rant
Edited by hrd-hr30
let's try that in context, shall we...
"First of all, I won't argue that he [Ricciardo] is doing a good job," he said. "On my side, I think I have plenty of qualifying sessions where we had some sort of trouble. I don't remember all of them, in terms of what the nature was, but we lost out many times because of that and in the races as well.
"At some times it was obviously getting quite frustrating, but Formula One can be very nice and it can be very brutal as well by not giving you the chance to show what you can do. I'm not interested in comparing too much, because on my side it's not fair to compare.
"Daniel has had a smoother year - I'm not saying perfect year because he's also had some issues - but way less than I had, so it's not entirely fair to compare. That's why I won't argue with that, he did a great job so far."
http://en.espnf1.com/redbull/motorsport/story/171711.html#cDlyEqGS8SSOEk2R.99
doesn't sound like he's being a tool to me.
Edited by hrd-hr30
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
