so i got a R32 GTS and well as you can expect from a N/A RB20 its rather sluggish. ive got a turbo motor that i bought, it came with the intake, turbo, dump pipe, ECU and oil lines.
the plan is to clean the turbo motor up and swap the good bits from the na block and transfer to the turbo block.
i have a few questions on thing im not clear with:
1. where do i put the AFM
2. is there any other sensors other than the AFM, O2, CAS, TPS that the GTSt has that the GTS has such as pressure sensor etc.
3. do i need a bigger fuel pump and pressure reg
possibly many more questions coming
thanx guys
https://www.sau.com.au/forums/topic/436198-gts-to-gtst-conversion/
Cheaper to buy a gtst than convert a gts
You have the engine but it seems you havnt considered the brakes and the many other little things you need to make this a sucessfull conversion
Ok here is a step by step guide I wrote up a while ago:
1. Put your car on carsales.com.au
2. Sell your car
3. Buy a GTS-T
4. Go on a $4k holiday overseas with the money you saved
5. Proceed to drive your GTS-T which is worth more, less expensive and better than a GTS +T
  • Like 1
From memory, it goes under / behind the airbox.
So: Airbox > AFM > Intake Pipe > Turbo
This!
oh yeah, did them and the hubs already
mostly just want the engine stuff, not bothered about everything else
Considering your car will have more power then the N/A engine, there will be things that need replacing in order to handle the power upgrade.
You'd want to look out for the clutch.
A brake caliper upgrade to the GTS-T model would be a good start.
At least a 3" turbo back exhaust will help with the exhaust flow.
Did the RB20DET you bought come with the side mount intercooler and blow off valve?
It's just a start to the "To Do List" for this conversion.
I may be missing something, but if you have a turbo motor sitting there, why not jut put that in?
Sounds easier then changing bits over, not to mention the comp ratio will be right on the turbo motor
If the turbo engine is blown then disregard this :)
Okay, so I have the hubs, rotors and calliper a from a GTS t, along with the ecu and motor from one
In regard to the AFM, I have a custom intercooler, now do I put it after the intercooler in regards to pressure drop across the intercooler or am I seriously wrong
The bits I'm swapping is just vacuum lines, alt, power steer pump etc
Exhuast will be custom made, got a HD clutch waiting to go in and haven't got a BOV as I told I didn't need one as it will only ever run 7-12 psi
Air flow meter measures air flow (hence the name) so pressure makes no difference, a good example is you get a cylinder of compressed air, you blow up a massive air balloon with it, the baloon takes up an entire room at atmospheric pressure vs the cylinder taking up a small space with extremely high pressure, is there more air in the cylinder? Answer is no hence assuming the pressure drop from the IC isn't due to a leak you still have the same amount of air.
If it was a MAP (pressure) sensor, then yes it would matter as it doesn't measure airflow, it just infers airflow from pressure.
Edited by Rolls
will bov or recirc valve increase perfromance and stop damage in any way
also do i need a GTS-t fuel pump or will and GTS one suffice
Not sure if they are different or not, I would get a replacement for peace of mind though.
BOV won't do anything for performance or damage, purely to keep noise levels down and stop popping/richness on gear changes.
well the cars off the road for a while so ill try the GTS one for a while and see how it goes
okay no worries
If it doesn't work it might still run but just lean and blow your motor up. Only way to know if it is working is with a wideband in the exhaust, a dyno shop could check it for you, wouldn't cost much more to just buy a new pump though.
I wouldn't run an RB20DET with the original factory turbo fuel pump. They're so old now that they're just waiting to die. On that basis, using the original NA pump would only be as bad, if not worse.
Bite the bullet, put in the $200 Walbro now and be done with it. Save yourself the headkicking you'd have to give yourself if you don't change it and it fails.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
