It looks as if there'll be several polar white and several bayside blue BNR34s rocking up Bobby.
Can you ask your photographer to stagger cars of the same colour so that they're not juxtaposed?
That'll help each car to be highlighted on its own merits - my 2c
No spectators they will be asked to leave .!we are organizing security for the night .terry need to speak to you about this.
Lowdown will be covering all the photo shoot .
Once we greet each other I think it will be a good idea to see and speak about each car .
Again this is only for r34 gtr owners and if they bring passengers that's fine 8)
got no problem with the idea of a 34 only meet, good luck to you, pics should be great.
But did I read right that you're hiring security to tell people to not look at your cars that you have chosen to park in a public carpark?
what if I buy a 34R from someone that is already at the meet, and I need to pick it up? can I came in an inferior car and then burn it at the gate and drive my 34R home? or do I have to organise a ride in a 34 R?
No this would be strictly against the rules. They are going to have security at this event to prevent this type of thing. You would have to buy another R34 GTR, say a week before hand, drive to the meet, supply 100 points of ID, rego papers, receipt for purchase of the car etc. You would then pick up the second R34 and then leave. You would then need to check what restrictions are in place after the event with the organisers in terms of disposing of one or both GTRs.
Just do it how they did for the R32 21st cruise etc.
for the cruise parts they broke everyone up by model of car, but everyone was quite well mannered and to put it bluntly, not a bunch of elitist assholes.
That's what I proposed to Bobby 8 days ago Matt; the fact that you, me and the other Execs organised an "inclusive event with segregation" and everyone had a good time despite the publicity buzz from newspapers, mags and videographers attracting many onlookers.
Since this is Bobby's 'baby', he's preferred an "exclusive event without elitism" - and that's the way he's intended it to be.
It IS a fine line to tread - exclusive - but not elitist - but I think he'll handle that quite well enough.
I believe from the outset, he gained formal permission to use the Costco carpark for his own private party (for BNR34s). This in essence means that a private carpark has been secured.
Other than that, I'm not privy to other arrangements.
On with the "Meet n Greet" if BNR34 guys wish to get to know one another better :)
  • Like 1
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
