Awesome, this has made my week.
I actually rang Shannons yesterday regarding this before I saw this thread and I was told I would save approx. $400/y on insurance alone if the car had club reg.
I was just about to send of application forms to Classic Skylines Australia because I thought club reg. may never happen through SAU, this is great news since I'd still be be much happier doing club events with SAU.
Can someone please clarify if the 25 year rule takes the build date into consideration?
If so, where is the build plate that states what month the car was built? I've got two plates I can find in my engine bay that, one silver tag with '609000HCR32066791'
the other blue plate says:
E-HCR32
HCR32-066791
RCR32GFSM GC
KG1 G
RB20DET 1998 cc
FS5W71C RC43
Not sure if any of this info refers to the build month.
Also,
Lets just say that someone with a 25yo skyline has had an RB25 conversion with all supporting upgrades that hasn't been engineered yet, but otherwise the car is in near perfect roadworthy condition (needs new rear discs), could it be put on club reg. without engineers certificate if it passes everything else?
Apologies if this has already been answered before in another thread?
Cheers,
Rob
25 year rule is meant to take build into consideration.
so from your VIN
July 1990
so 18 months till worry about.
engine swaps are technically allowed
however you need to show it is done well, all the brakes and such is done and the car is safe.
If a car is modified, VIC Roads may ask for a VASS certificate. Not sure if they actually enforce it though
so from your VIN
July 1990
Dang..
Thanks for looking that up for me Martin, I had no idea. For some reason I thought it was built earlier and something dodgy had been done to comply it as a 90 when I brought it in.
Everything else is above board with the car, pretty confident car would pass a roadworthy with new rear discs as long as height adjustable coil-overs are ok.
thanks Tony, I guess with 18months to wait there will be plenty of people that will test the water before my car is eligible.
Someone over at aus300zx just had his 89' club rego'd and the rules seem to be for imports it's only the year of manufacture that counts as they have no way of confirming the build date. Therefore come Jan 1 of your year you can get in
You can drive all day everyday if you like but only for 45 - 90 days a year. Depending on the permit you purchase.
If you are driving past midnight you just need to fill in the log book for the next day.
Ah ok, thanks for that.
this is good news...1 year to go can i club reg my cressi or is it skylines only?...then if i hang onto the skyline for 4 more years..:P
so sick of paying 700$ a year for a car that gets driven a handful of times...
Is there a limit on the amount of cars I could have under club reg?
So according to what people are saying here I can put a ls1 or rb25/6 in r32 or or s13 but dont need a engineer/vass certificate aslong as its a clean properly done setup? How about emmissions?
Dosnt vicroads say u need a eng certificate for major modifications?
Classic and historic
– manufactured after 31 December 1930, but more than 25 years before the date of the application for a club permit; or
Street rod
– manufactured more than 25 years before the date of application for a club permit and modified in excess of the guidelines contained within the Vehicle Standards Information
No. 8 (VSI8),
Guide to Modifications for Motor Vehicles
Modified vehicles should really be on Street rod plates , Original or close to original vehicles should be on Historic plates.
Suspension or Cancellation of Permit
VicRoads may suspend a club permit if it reasonably suspects that
a) the vehicle operated under the club permit is not an eligible vehicle; or
b) the permit holder is failing to comply with any of the conditions of the club permit; or
c) the permit holder has disposed of a vehicle and has not destroyed the club permit label and the vehicle's log book and removed the number plates
d) the permit holder is engaging in conduct which threatens public safety or undermines the integrity of the club permit scheme.
Not only does this effect the person and the car that is caught doing the wrong thing, it will also come down on the club/ safety inspector if the club doesn't require RWC for club reg.
Refer club permit application form:
http://www.vicroads.vic.gov.au/NR/rdonlyres/4BC78D16-7C1D-4DCC-B0E7-A3932C2FD2DF/0/ClubPermitApplicationFeb2011.pdf
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
