Hi all,
Iv been looking around, and cant seem to find anyone having done this.
My concern is, when I shut the car off, after a minute I can hear water start to bubble, not like sizzle at all but just pop away slowly.
It did it with the garrett and with the new efr. The lines come from factory points, are free from blockage etc.
Im wondering if a small transfer pump hooked into the line would be of benefit, to get more water going faster.
Or if its not worth worrying about.
So has anyone heard of it being done?
What pump would work?
Is it a problem? - more to the point of getting air in the system.
Thoughts?
https://www.sau.com.au/forums/topic/436744-turbo-water-cooling-pump/
When water boils it turns into water vapour and when it cools it condenses back into a fluid . The whole idea of having a water cooled turbo is to stop the heat in the manifold and turbine housing conducting into the centre housing and cooking the oil in the bearings mainly after shut down . It only has to work for about five minutes and provided the water vapour bubbles can rise out of the centre section without forming vapour locks it should work fine .
Just remember the water line out of the turbo must let the coolant rise to a higher point in the cooling system or it's hard to make it thermosiphon properly .
A .
You can run no coolant through your turbo and it will be fine providing you cool it down considerably before turning the engine off. The only real reason is to keep the oil temps under control, it is rare a turbo gets so hot it actually melts and warps studs/housing, though I have seen it on a GTRS running 20psi on a 25 that was being tracked.
I wasn't aware it thermo siphoned when you shut the car off, so it makes a big difference where you plumb your coolant lines from, something worth remembering.
Edited by Rolls
Garrett etc recommend the core be mounted so the water lines are at 20 odd degrees from memory for this exact reason, and youl notice that the stock water line runs uphill the whole way back to the intake manifold :)
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
