Ive got a brae hi mount manifold which pricewise is similar to 6boost but the construction and gains ive had cant be compared to cheap stuff you can buy under 1000 so I personally wouldnt go any of the cheaper stuff unless your on a budget and performance gains from it arent that much of a big deal.
Track work pushes manifolds to the limits, I would prefer the factory cast one, with factory heat shields personally, and then externally gate the turbo off the housing..
Just don't go too small for turbo housing, it will cause high egt's which no manifold will take for long... Ethanol (e85) will help with longevity.
Cheers guys... might save up and do it right the first time. Brae hi mounts? Are they as good as what people claim 6boost are??
Sure are quality is extremely high and brenton is great to deal with. Here is a pic of the inside of the collectors and dyno results of before and after manifold on my setup with only change being manifold and turbo converted to ext gate boost was at same psi
post-50426-0-70856200-1388217124_thumb.jpg.post-50426-0-20564800-1388217171_thumb.jpg
<br /><br />You are building a track car, go with the proven items. Cheaping out anywhere will punish you more than it would in a street car where you can sometimes get away with it. $1200 Is nothing
  • Like 1
Yer very true...
Also thanks for the pics. Very impressive dyno result just by changing manifold! A little shocked by it actually.
Any pics on car mate? or just in hand?
Hi all
Been a good read so far and as I am in the process if looking for a manifold I thought I would ask a few questions.
Now I know that the 6 boost that Kyle makes are a great unit $1260 and the Brae unit $1100 + also looks the goods but there are other manifolds out there that are cheaper that also look the goods but not much in the way of feedback.
Out of interest sake has any one had experiences with
At performance manifolds
D1 stable manifolds
Sinco custom manifolds
Hybrid performance manifolds
Cheers
Edited by FJ RB25
I would just go with proven results.
We went 6 Boost split with twin gates, why risk buying something for $1000 when for $200 more you have a life time warranty that it wont crack with a brand name known to be efficent and used on many big powered builds?
Hell if you want ot save a buck, heaps of others out there, have a google and enjoy reading about welds cracking......
Pay once, do the job once and forget about it.
GTRPSI
I'm hearing what your saying an I agree,
However if everyone purchased 6 boost and that was it then where would we be besides being happy and crack free?
There are other quality products out there and I was really interested in peoples experiences with them, if they are any good etc etc
We all know 6 boost are the best
Thank you Kiwi for the info I will check out your post
Cheers
Edited by FJ RB25
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
