hey there,
my series 1 stagea is sitting at stock height and has 18inch wheels.... i noticed it has the floating feel when driving, the rear tends to float over bumps and gives the feeling that its following any grooves or bumps or ditches in the road... i had similar thing in the past with my commodore wagon and a hilux but am told its because they are light in the rear end...
is there anything i can do to try and sort the issue, i do not want to put coilovers in can't afford and i dont want to lower...
First thing to look at would be your rear dampers. If they're old/worn-out then they will definitely make the rear end feel floaty. If they check out to be good, then the next step would be to inspect the UCA and LCA bushes. After 15 years the stock items will be on their way out.
It is a wagon after all, and is built with a large empty box at the back. On my old worn set of tyres, getting down to a quarter tank of fuel was like an arcade drift game...
something other than worn tires is causing that.
thanks for the info, its had an alignment and is on brand new tyres...not sure of profile size, i will get the dampers and bushes checked out this week.......as for replacement ones if it is the scenario what kind of price range would i be looking at?
you dont need to lower your car, a stock high ride height is fine and shouldnt feel dangerous.
take it to pedders or somewhere that will do a full check testing shocks and componants.
theywill try and sell you everyting pedders under the sun but just get the check done and go from there.
Just my 2c, when I had a pedders 28 point inspection, they missed everything wrong with the suspension. When I paid $120 for a reputable workshop to do an inspection they came up with a very very thorough list (also more than the suspension). Most opinions on pedders are about as flattering.
*** However, I should add that I did not agree with everything on the comprehensive list. I also made more cost effective repairs eg, the workshop wanted to replace the entire strut and spring assembly just to replace the shock. I replaced the shocks myself.
I guess my experience was almost the opposite. I knew something (or several things) was wrong in the suspension and pedders didn't pick up on them. - as opposed to workshops usually racking up unnecessary repairs.
yeah get what your saying zoomzoom... i would go tomorrow and buy a set of coilovers if i could believe me and i think if our 2nd child wasn't so close to due date i would... but it sucks the floating when i am driving on my own in car but once there is a little weight from family being car its almost non existent.... and i can't really lower the car at the moment with my wife so close u know
Lowering the car isn't going to make any difference. Stock height is not causing the problem.
Yes it does , lowering the car puts constant pressure on the strut and pre- loads the suspension , its a short term cheap fix without replacing stock struts .
Like i said , this fixed my problem and very well .
Now i run Bilstiens with Tein lowering springs actually works better for street ride and will outlast any coilover .
Then again coilovers might be your best option to keep stock ride height ?
Bad advice going to pedders ……...
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
