Ah really! So the rubber on my new rims will be ok, thats great to hear, gives me time to save for better tyres as well as being able to get on to Driver trainer sooner! :)
And I was wondering how good they were after reading a few reviews, people seemed 50-50 on them. But will check out OTR for these Hankook rs3's for later in the year. Thanks :)
Another question is where might I find small diameter wheel nuts? Gave a few places like Autobarn a call and they hadn't heard of them. I've seen them on ebay but I'm hesitant to buy anything car related off ebay other than gear boot covers and dash globes :P
I keep slimline wheel nuts or tuner nuts in stock to suit 12x1.25 and 12x1.5. Im in Moorabbin @ City Discount Tyres . $40 for a set with a key
I havent recieved my Cams lic. yet I guess Jan is a bad time to apply for one and hope for it quickly.... Can I have a club offical do the relevent sign off on the day? I have AASA but I dont hink they acceot that at PI
I'll be driving the evo, so we'll just be sitting our gear out in the open as well.
Has a track car and a daily
Track car off the road but can still track the daily lol
Dat Evo life
Richo can sort you out
Might need to come see you about a set! Or do you do postage at all?
Timing is provided on the day. You will receive it at sign in (around the corner from sign in).
I'll be there to sign temporary CAMS forms if required. Print it and bring it, as I won't be brining any.
Garage's can be hired on the day, generally they don't sell out at PI as they are silly $$$, so you should be ok. Ask at sign in.
Can everyone please make sure their fire ext are within date, you have been warned!
I can't comment on the 123's as I haven't used them. However the RS3 and AD08R are good tyres. I find the AD08 is a more progressive tyre to drive on and generally you can lap more consistently with it. Hot lap for hot lap they are pretty similar, but the AD08 will be 2-3 and even 4 in a row within a handful of tenths.
Does anyone have a spare set of R32 GTR or 33 GTS-T rear brake pads they could bring with them tomorrow. Can be crapy used ones. Just something to get me through the day.
Will pay what ever is needed.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
