Im after an oil pumpformy gtrand dont really wnat to spend the $1700 or so for a nitto, crank collar and machining, I know rb30's have a different geardesign, narrowdrive and dont seem to crack, however theyflow less. Im planning on running restrictors on the head feed, and a single turbo, which will both improve oil supply to the bottom end, am I mad?
Yep. You are mad. lol
Simon-s14 has a stock na bottom end with stock shimmed pump with 26 head in a drift car. But he is risking a stock sh rb30 bottom end so like 300bucks max.
weigh up the risk and decide
Just got on CT and found that heaps of people are running a8(turbo) pumps in big hp/8000rpm cars running down to 9's, just never heard of vls breaking pumps, seems to be a skyline thing. If simon s14 is running a stock na pump, then it would have even less load onthe drive flats, as they flow even less, wonder what his oil pressure is like
Edited by Adriano
Don't forget though they are all auto, leave the line off a loaded engine/transbrake and you never see them sitting on limiters during burnouts. Definately big factor differences.
It's certainly not the RPM that's the problem on a well balanced motor.
Where did you get $1700 for crank collar and install from? The collar itself is $150 and I had a wide crank collar fitted to an rb25 crank for a little over $100. Even if having the crank micro polished, straightness/crack/balance checked and grub screw cleaned you'll come in at well under a grand.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
