Can you go into a bit more detail? BE greatly appreciated.
Have you run the MX72 pads before? What pads were you running on your old original R32 brakes?
So you have not tracked it but sounds like you have driven it plenty on the street. Do you have ABS? You have uber power so guessing you have used them for hard stops? If you have ABS does it kick in far earlier than before? What % increase or decrease do you have in pedal effort to stop the car in general driving.
LOL, lastly what BMC are you running ... sorry about all the questions
Ive driven this a few times. This was before the mx72's though, Pedal feel was very close to stock for normal conditions but the pads were shizen and didnt pull up amazingly compared to my setup but mines silly when in speeding conditions. BMC was a BM57 running ABS
I have also driven pezheads GTR with the same setup but smaller discs with Hawk HT10's and it brakes stupid well! a very slight chirp in the last 5m coming to a standing stop in emergency braking situations no ABS shuddering.. Braking feel is similar to mine which is a bit touchier than stock on initial bite (needs less pedal effort about 10-15% less distance/pressure) so it will take maybe 20 mins to adjust over a daily but then its fine. This was also ABS and BM57
For Reference roy im running 33GTR brembo's with 345mm rotors, Endless CCRG pads and a BM44 also abs but it almost never kicks in.
  • Like 1
A few seconds with the DBA catalogue tells you that the height of the R34 rotor is 53.8mm and the height of the Evo9 rotor is 43.5mm. So trying to jam the R34 Brembo caliper over the Evo rotor is likely to result in disappointment. Of course, there would be little point in doing so, seeing as you can get the right rotors for that caliper.
If you're talking about some whacky custom fitment on some other car, then you are potentially free to make your brackets so that the rotor is centred in the caliper. You could also then locate the caliper so that the 4mm difference in diameter is not so much a problem.
  • 2 years later...
On 28/04/2014 at 4:55 AM, RBN1 said:
Interesting. These are the prices I got when looking at this option:
$350 ALPHA OMEGA Evo 350mm Brembo billet aerospace alloy caliper adapter kit
$850 Pair of Mitsubishi Lancer Evo 5, 6, 7, 8 or 9 Brembo front calipers (used)
$120 Brembo caliper rebuild kit for one pair of calipers
$200 Brembo brake caliper rebuilding service for one pair of calipers
TOTAL = $1520
+cost of Discs and Brake lines.
I opted to go for the D2 8 Pot 356mm kit instead. Bigger, cheaper and came with everything required. (and it's all brand new)
Would you guys vote for D2 over brembo ?
Edited by stranger12
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
