Seems someone stole 10 rims from my backyard in Hampton Park last night, someone that has been here before. I am extremely disappointed to say the least.
As most of my customer base is on SAU, I am posting to politely ask for their return, as if I eventually find out who stole them, I won't be so nice about asking for them back. They weren't mine, and the owners will be more pissed than me, that's for sure.
I will get some photo's up soon, hopefully they try to offload them locally and you guys can keep an eye out for them.
https://www.sau.com.au/forums/topic/438735-dirty-thieving-priks/
How do you know it was someone who has been to your house? Obviously came prepared, that or there were more than a few people to carry that many wheels...but were they hidden from cover or something?
They just took the rims as far as I know, and they came prepared as you said. I would say they had been before and spotted the rims, and saw a quick buck to be had. Still waiting/looking for photo's.
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
