Hi all, looking for a decent radiator to chuck in my R32. I would like one that lets me retain the standard radiator shroud and doesn't cost me ridiculous amounts of money. Running a 52mm ebay special and would like to drop down to a ~42mm one so i can keep the shroud.
300+kw RB25DET Neo running ~20psi gets very hot on track. Was maybe 30deg ambient temp and was sitting around 92 at idle and got over 100 after 2-3 laps so i did cool down laps until it was back at low 90's. I am running a GKtech clutch fan also.
Any advice welcome, thanks!
https://www.sau.com.au/forums/topic/438910-radiator-suggestions/
  • Replies 72
100 degrees or more is fine for a hot day imo. You will probably find the track temp is 40+ so the radiator was doing a fairly good job. Getting the shroud back on should be a priority though, can you get something fabricated in alloy perhaps?
RB25DET NEOs run 90 degree thermostats, see if you can fit a 80 degree one.. also check with Trent if he has mad any fuel corrections at 80 degrees, if he hasn't go for it :)
I bought the wrong thermostat and my car also sits at 90 degrees.. I'm using a dim sim 43mm radiator and on the track I don't go over 110 degrees with the water
Changing the thermostat will make no difference whatsoever to track temps!
I guess so, however what I was trying to get at is say at normal operating temps your car runs at 80 degrees, and then you bash it around the track you have more headroom before you hit say 120 degrees, where as if you're running a 90 degree thermostat you having less headroom.
I'm happy to stand corrected :)
I knew Neos ran hotter (to meet more stringent emissions standards?) than standard 25 but I still thought 110deg was excessive. Ideally I would like to keep it around 100 but if that is unreasonable without a huge cooling set up then ill just take reasonable steps to keep it down and monitor it.
So anything under say, 115 deg is fine while thrashing it around the track?
The other thing I was slightly worries about is how hot the intake plenum gets, I know it has coolant flow through the neck of it but it gets very hot, to the point of burning you hand if you leave it longer than a second. This is after a gentle 20 min cruise doing 100 on the highway.
I had similar issues with my R33 runnning a GT30 and a 52mm ebay radiator. Although mine fit with the shroud.
Day to day it was the same, but on track i was only gettin 2-3 laps if i was lucky and hitting 100+ too.
I think the issue is having the inlet/outlet on the same side of the radiator. If you go too big with the water tubes i think the water drops through the radiator too quickly, and doesnt efficiently use the whole surface area of the core.
I always intended on moving the outlet to the opposite end and turning it into a Tri pass.
Anything 110 or under is usually fine.
My Neo topped out around 108-109 after about 5 hard hard laps. That is Without a shroud, Stock clutch fan.
I have wrapped all my intake/crossover pipe/intercooler piping in exhaust wrap, this was the best thing i did as i no longer get Heat soak.
I'm going to guess THIS is your problem not the radiator itself.... I have run a Triple Pass RacePace radiator and had no temp issues on hot days and texis etc... The minute i changed to the GKTECH fan i was overheating in 4-5 laps of EC.... I am going to swap back to stock fan and run again on the 26th, ill update my build thread with the results...
good to see some hard facts :)
then again the stock fan blades are larger, in terms of surface area so you would think it will/would move more air than a smaller fan.
Interesting. I do have a stock fan still sitting here, so may see how the GKtech one goes and if it's no good ill swap it for the stocker and see if it makes a difference.
I'm doing winton drift matsuri this weekend and i will be taking 2 radiators, 2 clutch fans and a set of twin thermos. Surely that is enough to keep it cool? hahaha
^ just in case some dim sims go exploding LOL
I got a mate who insisted that GK Tech fans were awesome sauce (S15 owner duh!) so he invested in their fan, and radiator.. guess what? his water temps are now higher than his stock setup.. lol
he's going to wakefield with me next month, probably wise to bring along the stock rad & fan too lol
Ill be swapping it off as my car is getting hot at idle and high speed yet not at cruise (I did 500kms on a hot day with no prob at all) so it really does lean towards the fan issue... The stock fan should pull more than enough air! I guess i swapped the the GKTECH as it was black and suited my engine bay but it will now get removed for a comparison!
I could be wrong, but pretty sure the fan is the main issue!
Well on that note, the SR seems to respond REALLY well to the fans and there are plenty using them with great success, for some reason the RB setup does not seem to favour the fans! There is another thread on them where people are going back to stock... It is interesting!
I would suggest your mate with the S15 bleeds his cooling system properly and makes sure everything is working properly as the SR generally goes good with it!
Retaining the OEM under-engine splash tray goes a long way to helping maintain airflow through the radiator core at higher speeds. There has to be a pressure differential across the core before airflow takes the heat away.
I see the same gradual loss of temp control at low speed on my VQ25det using a GKTECH fan; once moving temps come down very quickly.
It could be running in the low 80's (Nismo thermostat and a large 2 core alloy rad with factory shroud) and slowly creep up until it is into the low 100's, then once back above 70km/h temps will drop straight back to low 80's again. Also sound like a bloody aircraft taking off; which I hate.
Fortunately I only paid $20 for mine (when they were selling pre-orders) so I won't be too upset to chalk it up to experience...
I don't think it is a coincidence Matt.
This was something i was also going to try! Thanks for the input Dale!!!
Nice to know! Well not nice but good to see its not just me blaming the fan! Amazing how it just doesn't work for our engines yet SR's love them!
On that note, mine is quiet, most complain about the noise but i didn't really have that issue... Maybe i should buy a fan hub too just to be safe?
yeah I'll give that a crack, I told him not to buy it but he's a GK Tech fan boy so he bought it along with a bunch of their suspension arms, after I specifically told him ONLY to buy the rear camber arms LOL
I have the front castor arms, im a bit of a fan of them compared to the other shit Chinese ones i had lol
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
