Hi all, looking for a decent radiator to chuck in my R32. I would like one that lets me retain the standard radiator shroud and doesn't cost me ridiculous amounts of money. Running a 52mm ebay special and would like to drop down to a ~42mm one so i can keep the shroud.
300+kw RB25DET Neo running ~20psi gets very hot on track. Was maybe 30deg ambient temp and was sitting around 92 at idle and got over 100 after 2-3 laps so i did cool down laps until it was back at low 90's. I am running a GKtech clutch fan also.
Any advice welcome, thanks!
https://www.sau.com.au/forums/topic/438910-radiator-suggestions/
  • Replies 72
100 degrees or more is fine for a hot day imo. You will probably find the track temp is 40+ so the radiator was doing a fairly good job. Getting the shroud back on should be a priority though, can you get something fabricated in alloy perhaps?
RB25DET NEOs run 90 degree thermostats, see if you can fit a 80 degree one.. also check with Trent if he has mad any fuel corrections at 80 degrees, if he hasn't go for it :)
I bought the wrong thermostat and my car also sits at 90 degrees.. I'm using a dim sim 43mm radiator and on the track I don't go over 110 degrees with the water
Changing the thermostat will make no difference whatsoever to track temps!
I guess so, however what I was trying to get at is say at normal operating temps your car runs at 80 degrees, and then you bash it around the track you have more headroom before you hit say 120 degrees, where as if you're running a 90 degree thermostat you having less headroom.
I'm happy to stand corrected :)
I knew Neos ran hotter (to meet more stringent emissions standards?) than standard 25 but I still thought 110deg was excessive. Ideally I would like to keep it around 100 but if that is unreasonable without a huge cooling set up then ill just take reasonable steps to keep it down and monitor it.
So anything under say, 115 deg is fine while thrashing it around the track?
The other thing I was slightly worries about is how hot the intake plenum gets, I know it has coolant flow through the neck of it but it gets very hot, to the point of burning you hand if you leave it longer than a second. This is after a gentle 20 min cruise doing 100 on the highway.
I had similar issues with my R33 runnning a GT30 and a 52mm ebay radiator. Although mine fit with the shroud.
Day to day it was the same, but on track i was only gettin 2-3 laps if i was lucky and hitting 100+ too.
I think the issue is having the inlet/outlet on the same side of the radiator. If you go too big with the water tubes i think the water drops through the radiator too quickly, and doesnt efficiently use the whole surface area of the core.
I always intended on moving the outlet to the opposite end and turning it into a Tri pass.
Anything 110 or under is usually fine.
My Neo topped out around 108-109 after about 5 hard hard laps. That is Without a shroud, Stock clutch fan.
I have wrapped all my intake/crossover pipe/intercooler piping in exhaust wrap, this was the best thing i did as i no longer get Heat soak.
I'm going to guess THIS is your problem not the radiator itself.... I have run a Triple Pass RacePace radiator and had no temp issues on hot days and texis etc... The minute i changed to the GKTECH fan i was overheating in 4-5 laps of EC.... I am going to swap back to stock fan and run again on the 26th, ill update my build thread with the results...
good to see some hard facts :)
then again the stock fan blades are larger, in terms of surface area so you would think it will/would move more air than a smaller fan.
Interesting. I do have a stock fan still sitting here, so may see how the GKtech one goes and if it's no good ill swap it for the stocker and see if it makes a difference.
I'm doing winton drift matsuri this weekend and i will be taking 2 radiators, 2 clutch fans and a set of twin thermos. Surely that is enough to keep it cool? hahaha
^ just in case some dim sims go exploding LOL
I got a mate who insisted that GK Tech fans were awesome sauce (S15 owner duh!) so he invested in their fan, and radiator.. guess what? his water temps are now higher than his stock setup.. lol
he's going to wakefield with me next month, probably wise to bring along the stock rad & fan too lol
Ill be swapping it off as my car is getting hot at idle and high speed yet not at cruise (I did 500kms on a hot day with no prob at all) so it really does lean towards the fan issue... The stock fan should pull more than enough air! I guess i swapped the the GKTECH as it was black and suited my engine bay but it will now get removed for a comparison!
I could be wrong, but pretty sure the fan is the main issue!
Well on that note, the SR seems to respond REALLY well to the fans and there are plenty using them with great success, for some reason the RB setup does not seem to favour the fans! There is another thread on them where people are going back to stock... It is interesting!
I would suggest your mate with the S15 bleeds his cooling system properly and makes sure everything is working properly as the SR generally goes good with it!
Retaining the OEM under-engine splash tray goes a long way to helping maintain airflow through the radiator core at higher speeds. There has to be a pressure differential across the core before airflow takes the heat away.
I see the same gradual loss of temp control at low speed on my VQ25det using a GKTECH fan; once moving temps come down very quickly.
It could be running in the low 80's (Nismo thermostat and a large 2 core alloy rad with factory shroud) and slowly creep up until it is into the low 100's, then once back above 70km/h temps will drop straight back to low 80's again. Also sound like a bloody aircraft taking off; which I hate.
Fortunately I only paid $20 for mine (when they were selling pre-orders) so I won't be too upset to chalk it up to experience...
I don't think it is a coincidence Matt.
This was something i was also going to try! Thanks for the input Dale!!!
Nice to know! Well not nice but good to see its not just me blaming the fan! Amazing how it just doesn't work for our engines yet SR's love them!
On that note, mine is quiet, most complain about the noise but i didn't really have that issue... Maybe i should buy a fan hub too just to be safe?
yeah I'll give that a crack, I told him not to buy it but he's a GK Tech fan boy so he bought it along with a bunch of their suspension arms, after I specifically told him ONLY to buy the rear camber arms LOL
I have the front castor arms, im a bit of a fan of them compared to the other shit Chinese ones i had lol
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
