Had to get her out of the garage as i needed to get to stuff behind it. Thought i would wash it whilst it was out of the garage. Washed it, clay bar, Waxed the whole car. Wen't to my dads to help move house.
Came back and the car was bright yellow covered in pollen. Had to go over the whole thing again. Game me no time to get anything else done. I'm now waiting for more paints to arrive in the mail.
But i now have a clean car. So i got that going for me... Which is nice.
Need opionions.....
Looking into getting 1 these 3 items when my tax comes back....
Full greddy intercooler/suction hardpipe kit (ill keep the standard twin turbo pipe)
Full Nismo interior
nengun-4323-06-nismo-skyline_gtr_r32_seanengun-4323-00-nismo-skyline_gtr_r32_sea
Or
HKS super turbo exhaust
Leaning towards the Nismo interior. Though unsure.
Isnt the Nismo interior just a hugely expensive set of vinyl seat covers?
effectively. Yes.
What's wrong with your current intercooler piping and exhaust?
Want something less loud for the zaust. And want the piping cause looks (for now)
Small update. Though it's little things like this that make me love working on this car.
New centre console mats!
Such a small thing but to me it makes the world of difference.
  • Like 1
Hah! I've owned R32's since 2002 and didn't even know that they had them. Nice!
Thanks for the part numbers too!
:cheers:
Nice I didn't know these were available separately, will be ordering a set myself
yep! i was looking around as the old mat that goes in the coin part had rotted and completely fallen apart so i took it all out.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
