Hey guys. My 32 gtr is completely standard besides visual mods, exhaust and gauges swapped for aftermarket ones. My car has felt like it has been performing a bit shitty for a whole now - several months. Just no pull on the top end. I have plans to go for a 300kw build for a while because of this but nevertheless I have still been driving her around taking it easy.
However the other day I was pulling up a hill and she literally wouldn't climb over around 4,000, since then she won't climb over that mark under load but free revving it will hit limiter. I'm thinking turbo issues. I've checked all lines and they are fine. The obvious maf sensors, I've changed the blow off valves to other standard ones I had because they could just be leaking boost. Spark plugs changed and yeah. All lines sussed and nothing.
What do you think?
https://www.sau.com.au/forums/topic/439600-89-32-gtr-not-revving-over-4000/
I believe this is most likely to be a fuel delivery issue.
Filter obstruction
Pump flow
Pump voltage
Pressure regulation
Filter obstruction
Start doing some basic testing by checking for pressure and replacing the fuel filter.
What did you do, swap them with known good ones?
Have you pressure tested the intake?
I cleaned them and then unplugged them individually and revved the motor and she didn't climb over 2500 free revving which is like their fail safe isn't it?
And no I didn't. How would you recommend I do that?
Cheers ;)
Could still be the AFMs. Does it feel like it's surging or does it sort die in the arse when revving (under load)?
Cheers ;)
Don't change it all unnecessarily but definitely start testing things as you go.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
