Hey I read a Garrett PDF linked from the forced performance website the other day, about water cooling and heatsoak after shutdown. Mentioned that you should have about 20deg tilt on the turbo, and the water lines need to be smoothly running up and down, to encourage water flow after shutdown through the bearing core. I had no idea this was important.
May not be your problem of course. But if oil is not the problem...
  • Replies 57
this might sound dumb, but a person I knew killed 2 garrett gt3582rs awhile ago on his rb30, took him until the 3rd turbo to realise, he had plumbed up the water lines incorrect, instead of using the stock in/out on block he choose a different path and it wasn't a circulating path and there for killed them everytime.
Am going to take this 20 degree, in and out, business very seriously on my motor... I would be mortified if my GTX axed itself, such an expensive adventure for me.
Simon I think you should trial a hypergear for performance and see what you think. If the performance is up to your standards perhaps give one a go and help support a local business. We all know the customer service and warranty side of HG is incredible, so the change will surely solve your issues as long as the performance is up to par :)
Edited by GTScotT
What about the tune ?
Once killed a new turbo because the tuna retarded the timing which increased the exhaust temp and cooked the cartridge.
Also if that's the same turbo The turbo falcons run, I had exactly the same sound and had to have one rebuild just recently and was told the bearing cradle is made of plastic and it had disintegrated. He replaced it with a brass one, said he was rebuilding 5-6 every week. Cars only a few years old and was rebuilt 6 months early as well. Seems to me they are a fragile turbo. Maybe time to try a different one.
Yeah my turbo guy has had the discussion with Garrett but they didn't want to know. So he has his own cradles machined, because he was seeing so many of the same failure. My wife's car ( turbo territory) completely stock is on it's 3rd turbo, with less than 100k on the clock.
Grant @ Per4manz turbos in Perth is my guy.
Does smashing limiter have any affect on turbo life
It might. Ignition cut limiter, whilst being kinder to the engine, does pour a lot of unburnt mixture out into the ex manifold and that stuffs already burning as it leaves the engine. So it will dump a hell of a lot of heat into the turbo. A plastic bearing cage might give up the ghost where a metal one wouldn't. It's a valid theory.
The best part of the theory too is that different days will see you limiter bashing more or less. So you could easily run it a few times and not kill it, then on one given day, bash it a bit harder and goodnight nurse.
yes and all... but to be honest i smash limiter hard too same as you (and have ignition cut through vipec) and my gtx3076 been going nearly 2 seasons strong
i know you've covered it but just for ref 3 guys did turbo's over here this year ... all 'oil starvation' issues no one could prove it was or not ... garrett no help at all with anyone just said 'setup fault'
Edited by bcozican
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
