Hey I read a Garrett PDF linked from the forced performance website the other day, about water cooling and heatsoak after shutdown. Mentioned that you should have about 20deg tilt on the turbo, and the water lines need to be smoothly running up and down, to encourage water flow after shutdown through the bearing core. I had no idea this was important.
May not be your problem of course. But if oil is not the problem...
  • Replies 57
this might sound dumb, but a person I knew killed 2 garrett gt3582rs awhile ago on his rb30, took him until the 3rd turbo to realise, he had plumbed up the water lines incorrect, instead of using the stock in/out on block he choose a different path and it wasn't a circulating path and there for killed them everytime.
Am going to take this 20 degree, in and out, business very seriously on my motor... I would be mortified if my GTX axed itself, such an expensive adventure for me.
Simon I think you should trial a hypergear for performance and see what you think. If the performance is up to your standards perhaps give one a go and help support a local business. We all know the customer service and warranty side of HG is incredible, so the change will surely solve your issues as long as the performance is up to par :)
Edited by GTScotT
What about the tune ?
Once killed a new turbo because the tuna retarded the timing which increased the exhaust temp and cooked the cartridge.
Also if that's the same turbo The turbo falcons run, I had exactly the same sound and had to have one rebuild just recently and was told the bearing cradle is made of plastic and it had disintegrated. He replaced it with a brass one, said he was rebuilding 5-6 every week. Cars only a few years old and was rebuilt 6 months early as well. Seems to me they are a fragile turbo. Maybe time to try a different one.
Yeah my turbo guy has had the discussion with Garrett but they didn't want to know. So he has his own cradles machined, because he was seeing so many of the same failure. My wife's car ( turbo territory) completely stock is on it's 3rd turbo, with less than 100k on the clock.
Grant @ Per4manz turbos in Perth is my guy.
Does smashing limiter have any affect on turbo life
It might. Ignition cut limiter, whilst being kinder to the engine, does pour a lot of unburnt mixture out into the ex manifold and that stuffs already burning as it leaves the engine. So it will dump a hell of a lot of heat into the turbo. A plastic bearing cage might give up the ghost where a metal one wouldn't. It's a valid theory.
The best part of the theory too is that different days will see you limiter bashing more or less. So you could easily run it a few times and not kill it, then on one given day, bash it a bit harder and goodnight nurse.
yes and all... but to be honest i smash limiter hard too same as you (and have ignition cut through vipec) and my gtx3076 been going nearly 2 seasons strong
i know you've covered it but just for ref 3 guys did turbo's over here this year ... all 'oil starvation' issues no one could prove it was or not ... garrett no help at all with anyone just said 'setup fault'
Edited by bcozican
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
