So its time to replace the fuel filter on the skyline again and I'm not a fan of the Ryco stuff.
Obviously I will be getting a Z32 filter for larger filtration, but has anyone had any experience with either of these?
$(KGrHqV,!nUF!IcLpmimBQGQFNQye!~~60_12.J
http://www.ebay.com.au/itm/Skyline-GTS-T-Uprated-High-Flow-Fuel-Filter-FREEPOST-/160246942699?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item254f764beb
Lets read
Uprated High Flow, High Performance Filter
If you are running a tuned GTS-T engine you need one of these high flow, high capacity, Japanese made, Fuel Filters. Hesitation under acceleration can often be a blocked or inadequate fuel filter. Cars running higher horsepower will benefit from the larger capacity reservoir of the fuel filter which means there is more fuel reserve to call on under wide open throttle conditions near maximum revs. This is the same reason to change to a larger capacity fuel rail, but this filter is an inexpensive and worthwhile alternative until you actually need one."
OR this one made by an Australian company
http://www.ebay.com.au/itm/Premium-Quality-Fuel-Filter-Z202-Suitable-For-/251372626532?pt=AU_Car_Parts_Accessories&fits=Plat_Gen%3AZ32&hash=item3a86f9e264
Edited by sonicz
Why would you not be a fan of the Ryco stuff? These filters are all approximately the same, except for the offbrand ones that no-one knows that just might have nothing useful inside them.
I suggest you do some googling on the fuel filter myth. Unless you have a major fuel related incident, you shouldn't really ever need to change the filter as they should last longer than the car in most cases!
Edited by GTSBoy
Ithink what everyone is trying to say is...just get a ryco
unless ethanol.....my ryco blocked up in about 3000km
Yeah, well that might qualify as a "major fuel related incident". Put a load of different solvent into a tank that's been collecting crud for 20 years.......
  • Like 1
To answer most peoples question, I guess I Just don't see any good reason to like Ryco or believe they are any good. The fact most people use them doesn't say anything about the actual product to me. So not a fan. In fact I have seen reasons not to like them. Here is one example
http://www.skylinesaustralia.com/forums/topic/415000-oil-and-fuel-filters-which-ones-are-not-now-made-in-you-know-where/
I cant see how the exact opposite of that isn't true. Its an easy to service important part of a vehicle. Why not change it?
Actually most people that check the inside of their fuel filters find a barrage of dirt and crap inside them. See the thread above.
Different car, same build up.
Edited by sonicz
Running ryco for 3 years on e85 never had a problem I change after every year track season and cut them open to inspect and they are perfect so definately nothing wrong with them, ofcourse if you just switch to e85 you need to change it after a few 100ks since it picks up some shit but after that no worries.
Heres a pic of my filter from last year.
  • Like 1
For every one of those there are 10000 filters thrown away with no measurable pressure drop (additional over when they were new) across them. And I have cut a couple of mine up over the years and there was almost nothing in them.
Fair enough. I'm still gonna try another brand though just for the sake of it. Looks like I'll order those big one from Japan. THEY ARE BIG IN JAPAN.
After I fit it this will play out of my Exhaust
http://www.youtube.com/watch?v=qutOSFit5Z8
Edited by sonicz
I ve used ryco and genuine Nissan over the years and cannot fault either. I change mine yearly which is def overkill in my opinion but hey Im anal with servicing my vehicles. Just piece of minf I guess
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
