There was a sticker on eBay not a long ago which I can't no longer find of a sticker figher man walking his Godzilla with a rope around it's neck and the words "my family..." it rocks...hahaha
Yea it's a bit rude I would say, I have My tuner across the top of my rear window but I asked for it..
I was thing about getting "destroying V8's since 1989" in the lower left corner of my rear window just to stir some shit heh heh heh
  • Like 1
I'm not big on decals at all, and my tuner has just jammed massive decals of his business on my GTR.
What's the general consensus about this?
Should I give him some advertising time or rip them up like a fat chicks phone number?
... You can't be serious.
I'm generally happy to offer "advertising space" to clubs like SAU (as above) because it enhances the enthusiast community and can even help build friendships when you come across someone else you otherwise didn't know was a member.
I'll allow stickers from tuners etc if they've offered me a discount or I'm particularly happy with their work. Other than that I can't stand them. There's a large chain of tyre stores (Tony's) in NZ that put a sticker on every car that comes through them but I pull them off straight away because I can't stand that I've had to haggle them down on price to start with rather than them just giving me their best price up front. Also, their wheel alignment skills at the local outlet suck balls.
But if you're after a maximum aggravation sticker, go with something like "IF ITS TO LOUD YOUR TO OLD", complete with spelling errors. Guaranteed to annoy 94% of people with an education.
Edited by Hertz Donut
I bought a car from a dealership years ago and as soon as the paperwork was done I walked out to the car and peeled off the decal on the rear window advertising his yard. He looked like he'd just stepped in dog shoot but never said a word as i jumped in and drove away.
you know.......
this is actually pretty awesome.
  • Like 1
Stickers on cars are stupid. having said that, I once had one on my ceffy with those stick figure family members being hung and it said "F**k your family". And more mechanics seems to help themselved to advertising on people's cars. They did it to my on my 33 once although it wasnt a massiv sticker, just a little one.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
