Some Euro-trash. Just put some 12.5mm spacers on the front of the BMW and lowered it around 1.5" all around. I think the rear could comes down a little more but overall I'm really happy with the stock-but-tougher look.
  • Like 1
My Supra
Twin hybrid turbos, cams, decat, exhaust & a syvecs. Should be running about 450-460hp. Desperate to get back in a GTR though :(
What's missing from the Supra that you'd be keen to get into a GTR for? Never driven a Supra so keen to know.
My Supra
Nothings missing as such, Its a brilliant car to drive & is a lot of fun on the right road (on others its down right scary :laugh: )
I'd always wanted a GTR & sold mine way earlier than I wanted to :( Got some unfinished business with it :D
Yes!!! Love the 996!!! (Love the BMW also!!) Nice cars!
My Supra
I like that! I'd hate to know how much you spend on fuel in it though with UK prices! :O
Sensual....
  • Like 1
Very nice collection mate :thumbsup: Still have a big soft spot for the E36 M3. Yours is a 3.2 (Evo) yeah? A 1996, judging by the series 1 grille but series 2 rims, clear indicators and Estoril colour. Props if it's the 6 speed manual.
Here's my other contribution. 0-100km/h in 7.0 flat, not bad for 1970kg! :D
  • Like 2
Matt, what is it a 740 or 750? You know your Beemers as you're spot on. It's a 96, 3.2 Evo and yes a factory 6 speed. Most of the SMG cars are now manual converted as the pumps die and they're $9k for a new one, and all for a transmission that doesn't work that well at best. I love the way they look!
Most of my cars are what I ached for as a youngster but could just never own because of the $$. Ahh, nostalgia.
Enjoying this thread,
Super cool. I bet it's nice to drive? But 1970kgs!?! Holy schmoly thats a large lass!
Cheers boys! :) Christian, it cost a fair bit to put right (but would've cost even more had I bought parts from here instead of the States) but it was fairly cheap to acquire. 1 owner car with books, so that gave me some confidence. And yep you definitely feel the 5.1 metres and 2 tonnes when cornering, but it's sooo relaxing to roll to work and back!
Yeah Nick, it's a '99 740iL with the M62 4.4. Like the S52 they can have some Vanos issues but otherwise pretty solid unit as long as it gets the proper maintenance. Ah ok, I have seen quite a few converted ones on Carsales. I know a little about the E36 M3s as I have been very close to buying one in the past, just couldn't find the right one. I can totally relate to the idea of acquiring cars that one used to want as a teenager too. The E38 and the GTR are two of those cars, for me. So I consider myself lucky!
  • Like 1
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
