Pfft well woopty do its not all about brands but what it looks and sounds like, plus I happen to know a major police factor is a Milo can tip, have been told so by hwp at many rbt stations,I drive thirty thousand plus a year for work from qld to Tassie no defects,keep it sneaky is my motto. :-)
dis is soo much lol
Must apologise to Humbler and the OP, obviously I had far too much beverage at the BBQ yesterday.
...as has already been mentioned if you want to quiet it down, then loose the resonator/ hotdog and replace it with the largest oval muffler you can fit there.
already got a muffler maybe half a metre away from the cannon... can i put 2 mufflers? so ill have a cat, 2 mufflers and a cannon....
or ill go with a silencer...
Yes and you have had to much beverage today as well. Now its time for you to go away quietly. find another car forum to annoy.Oh an don't let the door hit your arse on the way out ta ta. :-) :-) .
I had a silencer in mine, restrictive but quieter.
As long as the Mufflers are large and free flowing you can have multiple if need be.
a while back i got noise epa'd on a quiet twin tipped oval 3" muffler in blitz season... cleared it and made up stock looking straight pipes 3" to twin 2" tips loud as, pulled over multiple times and not an epa as it all looked stock....
  • Like 1
Its too effn loud that it gave me a headache coming back from the exhaust shop. A xforce cannon with a 3 inch internal diameter. He said it would be louder than my previous jansai one but i didnt think it was gonna be this loud! The r32 even has a cat convertor and another resonator before the cannon and its doing my head in! what a waste of money!! do not buy these cannons for your own sake and everybody elses
Your original post said resonator?
So take it back to the shop and ask them to make it quieter. if you haven't scratched it up they may take it back and do a deal with a different setup.
My setup is 3" bell mouth dump to a catco ceramic, then to a large straight through oval, then it steps up the 31/2" to the cannon. tested at 88db.
na think I will stick around a bit longer.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
