  • 7 months later...
just spoke to dave at insight scott is in the us of a probably prepping for Sema he quoted me $3k+ for the Emtron I'm still not sold on it as he is the only guy capable so far for tuning it and if you know insight there always flat stick!!
https://www.sau.com.au/forums/topic/440531-emtron-ecus/#findComment-7416163
I think these are the ones my tuner was telling me about a while ago. Says they are an awesome bit of gear, if you can use it to its full cabability. So many inputs and outputs and will do just about anything. But this is going back a while so I don't remember in great deal what was said (or even if he was talking about these, although pretty sure Emtron sounds right) so my input might not be terribly valid
Basically, if you have been getting by with a Power FC, one of these is probably overkill. If you have use for all the functions then they are a good thing
  • Like 2
https://www.sau.com.au/forums/topic/440531-emtron-ecus/#findComment-7416192
I nearly got one of these but they weren't quite ready when I needed an ecu so I ended up with a Syvecs S8
From what I've heard from scott about these they are an awsome piece of gear and I believe they slot in between the M*00 series Motecs and the new M1* series which is about the same level as my S8 ( the backbone of the Alpha R35 kits )
They have patch looms for a few cars already and I believe they have one for R32-34 GTRs, and can pretty quickly make one for any Nissan
And for the price I was quoted for supply fit and tune ( not full retail so I wont say what that was, but that was still less then the S8 ecu alone ) you would want to be fairly serious about the engine management and be looking at a Motorsport/track use
https://www.sau.com.au/forums/topic/440531-emtron-ecus/#findComment-7417817
  • 1 year later...
I'm interested to know if anyone's gone any further with Emtron ECUs since this thread was last updated . I was speaking to Scott earlier in the week briefly about them and I like the idea of a more modern EMS that can take advantage of factory knock sensors and tune closer to the edge safely . He said that he is happier to do flex tuning with these systems than earlier ones and make full use use of fuel temp and pressure sensing .
I've gone back to 98ULP but I would like the ability to use E70 and be able to gas up anywhere , who wouldn't .
Thoughts , cheers Adrian .
https://www.sau.com.au/forums/topic/440531-emtron-ecus/#findComment-7783245
I know Efi up on the gold coast have installed a fair few. I think piggaz is getting one too?
Does seem more like a track focused ecu though, i did get a quote for one but something like a link g4+ offers a better blend of price/performance for my setup.
https://www.sau.com.au/forums/topic/440531-emtron-ecus/#findComment-7783300
Nick (Intune) has had one installed also. Both his and mine are KV8's. A little more expensive than the usual "Link plug in/Haltech whatever/blah blah" but it has more inputs and outputs then you can poke a stick at. All depends on what you plan on running with it.
You can get a patch loom made so you don't have to hack up your factory loom.
https://www.sau.com.au/forums/topic/440531-emtron-ecus/#findComment-7783304
I can't remember if Scott said they had or have a plug in version in the pipe to suit an R33 . I just think these KV8s sound like they use more OEM type strategies than the usual offerings . Things like volumetric efficiency tables and short/long term trim settings , more like a true self learning system than simply having closed loop oxygen sensing trying to trim conventional load/speed map systems .
He said these are aimed at motorsport applications and I guess like the current eco raped emissions engines competition engines need tighter control over what's happening running close to knock and temp limits . Race engines often have to have fuel consumption limits because of limited fuel stops/weight etc . I suppose emissions will be the next thing on the race engine hit list .
Anyway that aside I think tuning close to the limits safely gets the most out of whatever engine you have particularly when not driven at WOT and high revs . The things you can still call a car today feel reasonably crisp and have a broad spread of torque starting pretty early . I don't think its all purely the physical engine itself , modern engine management and tuning would have a big say in how these hot lean burn engines perform . By comparison an RB is a true dinosaur but getting a bit more out of them with smart electronics and tuning can't hurt .
A .
https://www.sau.com.au/forums/topic/440531-emtron-ecus/#findComment-7783314
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
