Mick how does your system go for noise suppression?
It would have plenty of flow capacity, be good to see pics for how it looks and fits.
It's a lot quieter then the 80mm jap exhaust I took off, it's not that loud until you get on the loud pedal then it gets up there, but idleing it has a nice tough murmur, Paul heard it tonight maybe he can comment on it
I have GT-RSs on the car so I needed as much flow as I could fit under the car
How about this , where your oxygen probe goes get a plug and drill/tap/braze whatever a take off into it and measure the pressure in the exhaust behind the turbocharger .
Compare it to boost pressure and note the difference .
It may not be a bad idea to pull the cat out and see if its blocked or collapsed as well . Changing that mid muffler shouldn't be a biggie surely .
A .
Couldn't hear it. All I heard what that farken pump. BBBBBZZZZZZZZZZZZZZZBBBZZZBBZBZZZZZBZBBZBZZZZZX
  • Like 1
That's not really the ratio you're supposed to look at against boost pressure though. Ex manifold pressure against boost - yeah, fine. But not really dump pressure. Realistically, if you have more than a couple of psi of back pressure in the exhaust you're looking at a substantial restriction. So measuring the pressure there is a fine idea, but you're really just looking for the absolute amount of backpressure.
It would also pay to measure after the cat too, just to see if the cat is the problem or if the mid muffler is the problem.
But, my 2c on that issue is (which coincides with a lot of opinions above)
1) Why not just drop the exhaust behind the dump and take it for a quick drive, see if it changes behaviour?
2) Unless there is a massive step down in the muffler(s) it should still handle quite a bit of gas flow without killing the power. So you have to wonder about tthe cat more than any other part.
Well this thread is about exhaust restriction and anything significantly positive behind the turbocharger under load tells a story . I just picked on the sensor location because it's an easy place to tap from . If that exhaust is restrictive and gets fixed the dump pressure should fall and so should the exhaust manifold pressure . Boost and power characteristics should change as well .
A .
What do you guys think of this - ok or a pile of junk? The cat is a gutted catco item (what I was suggested with a bit of reluctance), the mid-muffler looks 3" in/out (no necking like mine), the rear muffler is a crappy jasma cannon but free-flow from the look of things.
System is off a 33GTST goin for cheap ( I know 34 is slightly shorter) and the I'm thinkin of buying it..
Edited by rondofj
Doesn't seem too bad for $100
Has a gutted cat already and a 3inch in and out same side mid muffler so that shouldn't be a problem
Just sack that rear cannon as most jasma approved mufflers have a smaller inner pipe which the oval muffler should fix
Worth it for $100 imagine how much it will be for a new custom 3inch catback atleast $500
The step down pipe is rarely in the mid muffler
Is almost always in the rear muffler or cannon
If the mid muffler is stepped down it's usually on the inlet or outlet and not internal as that muffler isn't offset so will be straight pipe thru just perforated and packing around it
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
