Nulon Nationals kick off on 6th of April at the famous Bulahdelah Hillclimb. Round 2 is on the 4th of July at Wakefield and Round 3 at Cootamundra airport
Thanks To Nulon they have invited SAUNSW to compete at the NULON Nationals, with a multicar Team against other clubs!
The Pulse Racing Evo and other Crazy Beasts will be competing at the event
Please go to their facebook page and like their page.
The link is provided below
https://www.facebook.com/nulonnationals
Bulahdelah Hillclimb 5-6 April 2014
Wakefield track day 4th July 2014
Cootamundra Airport drags 20th September 2014
The Team representing SAUNSW for the first round at the famous Bulahdelah Hillclimb is
Mat 34geeteetee
Steve Ka
Brian
Nick Adams
Duncan
JLM
Please show your support for these guys and NULON for putting on such great events
Edited by crashdown
https://www.sau.com.au/forums/topic/441342-nulon-nationals/
I'll have to make it up to Wakefield to see this!
You do man! And bring the crew with ya to support the SAU team :yes:
There is hundreds coming to the Hillclimb event apparently so its going to be epic!
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7245862
Thank you to NULON for their commitment and lubricants! :)
We wish our Nissans the very best!
Can't wait going to be epic fun!!!
Thanks Terry! And certainly thanks Nulon!
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7245977
sadly my car isn't ready (just too much to get done in the last few days), but Neil is a champ and threw me Cheryl's keys. So this is my pic for the weekend
See you guys up there, should be an interesting event
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7246118
What amazing depth of quality cars in our club!
(Except maybe that nugget GTT... Jks :P. )
Good luck guys, take it easy up there, live to race another day.
You motherf**** :P But yeah i still wanna get a Nugget Motorsports sticker :laugh:
And YES live to race another day is a good motto, it is fast and it is not a prepped surface -
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7246557
Those new tyres should be better than the RSRs if it is damp. Andrew and I will be driving up early on Sunday for a watch.
Hope so, steer tyres are still 255 RSR!
where was my invite to be part of the team! :P
Do you even have enough power to make it up the hill? :whistling:
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7246723
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
