Hi all, Just bought a new house so time for a clean out.
R34 GTR genuine bonnet
In good condition, no dents or sctaches. Was going to use it myself but found something more suitable. Can provide hinges to suit r32
I paid $850 for it but im after $800
R34 GTT Genuine Nismo/Altia kit
All in fair condition, black in colour but would need a bit of a touch up. Still on car so photos up soon. Would prefer to sell as full kit but willing to part if enough interest. Kit includes front bar, bonnet, fenders and rear bar
$1000
R34 GTT passanger headlight
average condition, yellowed
$150
RB26 standard plenum
good condition, paint flaking a little.
$300
R33 RB26 standard turbos and dumps, pair
just pullled of standard motor with a little over 100,000kms on it, they look in fairly good condition. They only ever ran at 14psi.
$300
R34 GTT cluster and submete
Both in good condition and working when taken out of car. odometer reading approx 100,000kms
$350
R32 GTST dash cluster
Good condition, cant remeber how many kms.
$150
R32 dash cluster
Poor condition but good for parts. GTR spedo gtst tach.
$20
Riverside Trafficstars
18" perfect offset for a r32 or r33 gtst. Some gutter rash but in good condition. Tyers are shot.
$1200
350Z wheels
Good consition come gutter rash but solid rims. Two rims have average condition federal rsr tyres the other two have no tyres.
$500
Super Advan II
18" not sure of offset. fairly average condition. Full set, no tyres.
$500
All parts are located in Wollongong NSW. All prices negotiable within reason.
Contact David on 0450929080
Will be posting more photos in the next few days.
More photos can be provided on request.
  • Replies 42
Just a few more photos
350Z wheels
GTR trubos dumps and manifolds
will throw in heat sheilds
R34 Boot lid
Also for sale is a bayside blue r34 boot. Looks like it has some cracked paint under where the wing stays are mounted but apart from that in good condition
$200
WEEKEND PRICE DROP
GTR Bonnet $650, CHEAP!!
R34 Xenon headlight LHS $100
RB26 plenum $100
GTR Turbos, dumps, manifold etc $200
R34 GTT Cluster and submeter $250
R32 GTST cluster $100
Riverside trafficstars $800
350Z Wheels $300
Super Advans $150
R34 Boot $100
If you still have some of these in a couple of weeks why not bring them to the official SAU SWAP MEET on April 27th. Sounds like you need a van!
Located in Wollongong. To mount on a gtt you need gtr front bar, hinges and bonnet latch bracket but the original one can be spaced out to fit.
Sinista32 the gtr bonnet wont fit, the hinges are different and the bonnet latch is also different not to mention the gap between ur front bar and bonnet
Hinges and the bonnet latch mount are available from Nissan and aren't all that expensive. I also have a std gtr front bar in silver but I'm really not sure if I want to sell it yet or not.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
