Where to now?
I have an RB26 in good condition (not long been built), but at only 410rwhp it doesn’t exactly light things up.
Has the following:
Forged internals.
-5 turbros, HKS actuators.
Cast iron exhaust manifold, ported.
Tomei dumps.
Apexi exhaust.
256 degree inlet cam.
252 degree exhaust.
Cam gears.
75mm I/C with a hard pipe kit. Stock inlet manifold.
Power FC off Z32 AFM’s.
Blitz ID III boost controller.
Other stuff than means it wont go bang but that dont relate to output.
It came back from the tuner with 410 horsepower and a note that they could only get the boost controller to run to 16lb. It apparently made 22 with the wastegates shut but no idea what horsepower.
Questions are twofold:
On the assumption (perhaps misguided) that it’s the problem where do I go looking to properly diagnose the boost control fault as the shop couldn’t find it (They blamed the wastegate actuators).
Once the thing has been wound out to whatever boost it is capable of running I assume it would only be good for short of 500rwhp. So, the question is where do I go looking for more horsepower. The following options come to mind.
  1. Replace the twin turbo pipe with something aftermarket which may help a little.
  2. Go to a larger inlet cam (Poncam A?)
  3. Adjust cam gears for days on end.
  4. Dunno.
Please note E85 is not a viable option where i am.
https://www.sau.com.au/forums/topic/441477-400hp-rb26-where-to-from-here/
Twin turbo pipe is fine. Maybe put the divider in it but it won't be the cause of the low figure.
Cams won't help here. Stock cams will go much further than that. Something is Definately amiss.
Is there an approximate number that -5's can be made to run to - hp & psi?
Be happy if the cams are not suspect. Once had Poncams B's. They sucked teh balls off a mange ridden dog.
Thing is the power curve is about right when compared to an old, stock motor with much the same specs for bolt on stuff (dyno comparison dodginess aside). Within a few horsepower right along the range.
Depends on setup and supporting parts so impossible to say.
Funny that you say that about type B's :D.
305 kw at 16 psi isn't toooooo bad on -5's with such a basic setup. Needs more boost. Chuck 22-24 psi at it and see what happens.
Find out why you can not dial in boost, sort that then dial boost up to 22-24 psi, that should see you a lot close to the 500rwhp mark
What boost controller have you got, did you check the actuators where set correctly and identically
Dunno why boost cannot be dialed in. To the best of my understanding it was that the wastegates cannot be kept shut due to insufficient flow through the boost controller.
Controller is a blitz dual solenoid type.
What does set correctly look like on the actuators?
Not the first time these bcs have caused issues. Buy a turbosmart manual bc and bypass the blitz one all together. This is a good starting point. Just make sure the actuators have been preloaded though..these two thing fix 90% of this type of issue.
If /when you fix your boost control problem you say what's next after 500hp.
Really depends how much power you really want/are prepared to pay for.
Since you have already forged (and presumably balanced) the bottom end you won't be wanting an RB30 so you could have a look at bigger/ more modern single turbos .
I don't know if the PFC would hold you back in any way but you could consider a Link/Vipec
Have you done much about your brakes and suspension?
Wow.
Not saying they are better just saying if the ebc isn't setup right then a manual one is simpler to setup...just for fault finding that's all. This process has work many times in the past. Or don't do it this way and fix it another way...doesn't worry me.
It is most likely hoses on the wrong way after rebuild, go back and recheck your work
Has it worked at all in its current state, if so it could be a faulty solenoid, if not then check the hoses are right
To check actuators you have to apply air pressure at different levels and measure how far the arm has moved on both to make sure they have moved the same difference, manual bleed valve will not fix this, this will most likely not limit you to 16psi either
You will also need to check preload on the actuators, done the same way as above, but this time record the movement vs pressure appied, IIRC they should start to open about 2psi under what they should set at and be fully open about 7psi over, this is because they don't have the manifold pressure pushing the gate open internally, I could be a bit off with these as I haven't done it in a long time, and this is most likely the problem
Not enough air flow would result in over boosting as it doesn't have enough air to open the gates and shut gates means no bypass which gives to much boost
What happens if you turn off the boost controller
It will run to 22 psi or similar (without any finessing) but I want a decent controller.
On the assumption it will go to 500 I would be looking for small gains, say 30hp at most. Would not bother if it was too hard/expensive. the last thing I need is something with a Hollywood number and no midrange.
Brakes and suspension. Are they important? It is only 500hp after all.
But seriously it has had a huge amount of effort put into the handling and the brakes upgraded.
Manual? FFS.
The plumbing could possibly be wrong. Actuators might not be setup correctly.
Check setup.
Yeah will do. Hoping someone may have had a similar experience and be able to finger, say the solenoids as a common failure mechanism for example.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
