Yeah cheers guys.. One opinion I've been given is 24psi.. But I don't see how that could be the case as long as the spring tension etc is right and you aren't revving it stupidly high you shouldn't get any valve float (which seems to be the issue with these heads throwing shims),
Also I could probably find it somewhere but does anyone know what the biggest cams you can go without losing the vct
Edited by Huzqld
Poncams but why are you doing cams anyway? Usually a lot of other priorities for the dollar.
  • 5 months later...
Hey guys I have gone ahead with this neo30 build. Instead of starting a new thread I'll just ask in this one.
Have just setup the timing belt with one idler and a tensioner (one above water pump). All the marks line up pretty well. Is it worth while getting an Adjustable cam-gear for the exhaust side?
I'll be keeping VCT so guessing I dont need anything for inlet side
(Standard cams to start with)
Cheers
Ian
Edited by Huzqld
Cheers
Ian
I have a spare VCT ring (good for dialing in cams on 30's) for the intake side if you would like to purchase. Apparently they have about 4 deg of movement.
If it was me id do 260 type b poncams/ neo head/Precision 6466 T4 /e85, comp in the low 9's
the only trans that won't explode would be a glide or a Th400.
thats a combo id sell to a customer wanting the best of both worlds
Id prefer a neo head over a 26 head as it would come up quicker on a torque converter due to inlet manifold design
and i bet it would make more power under the curve making it a better street proposition
its a better street deal all round
Need to run into the 8s to even start to justify a 26 head
cheers
darren
Cheers Darren
I've already got the 35/40 from my sohc setup (it's a VL) and a re401a auto. I Got the manifold with a heap of parts and it has t3 flange so later I'll upgrade the turbo and manifold or just get flange changed. I plan on putting some type b poncams in it but would just like to see the difference from std cams.
Close to 9:1 comp
Specs of motor
Spool I beams
Wiseco pistons
Asr 8.5l sump
Arp main and head studs
N1 oil pump with billet gears and crank collar
Cpc plenum
Steam pipe manifold
Standard head besides springs and retainers
Ross balancer
Ian
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
