Yeah cheers guys.. One opinion I've been given is 24psi.. But I don't see how that could be the case as long as the spring tension etc is right and you aren't revving it stupidly high you shouldn't get any valve float (which seems to be the issue with these heads throwing shims),
Also I could probably find it somewhere but does anyone know what the biggest cams you can go without losing the vct
Edited by Huzqld
Poncams but why are you doing cams anyway? Usually a lot of other priorities for the dollar.
  • 5 months later...
Hey guys I have gone ahead with this neo30 build. Instead of starting a new thread I'll just ask in this one.
Have just setup the timing belt with one idler and a tensioner (one above water pump). All the marks line up pretty well. Is it worth while getting an Adjustable cam-gear for the exhaust side?
I'll be keeping VCT so guessing I dont need anything for inlet side
(Standard cams to start with)
Cheers
Ian
Edited by Huzqld
Cheers
Ian
I have a spare VCT ring (good for dialing in cams on 30's) for the intake side if you would like to purchase. Apparently they have about 4 deg of movement.
If it was me id do 260 type b poncams/ neo head/Precision 6466 T4 /e85, comp in the low 9's
the only trans that won't explode would be a glide or a Th400.
thats a combo id sell to a customer wanting the best of both worlds
Id prefer a neo head over a 26 head as it would come up quicker on a torque converter due to inlet manifold design
and i bet it would make more power under the curve making it a better street proposition
its a better street deal all round
Need to run into the 8s to even start to justify a 26 head
cheers
darren
Cheers Darren
I've already got the 35/40 from my sohc setup (it's a VL) and a re401a auto. I Got the manifold with a heap of parts and it has t3 flange so later I'll upgrade the turbo and manifold or just get flange changed. I plan on putting some type b poncams in it but would just like to see the difference from std cams.
Close to 9:1 comp
Specs of motor
Spool I beams
Wiseco pistons
Asr 8.5l sump
Arp main and head studs
N1 oil pump with billet gears and crank collar
Cpc plenum
Steam pipe manifold
Standard head besides springs and retainers
Ross balancer
Ian
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
