i too would like to know how a private company can influence another private company legally and put them out of business....
"legally" ?
since when did the private companies in question give two shits about legality?
JOC provided a fantastic service - these newcomers will have big shoes to fill...
Do you think that an alternative career path for them might be politics?
Fb likes = 596
The only profession where it's a prerequisite to be lower than a snakes arsehole...sounds like politics would be the perfect career path for them.
Hi All ,
I understand that there are some qualms about JOC. I wanted to come out and clear it all up instead of stories flying around.
Our Japanese operative was threatened in the comfort of his own home.
For those that have paid for their checks, you will get your results.
Mick, I believe I have sent out your results to you as of 2 weeks ago. Please check your E-mail inbox. If not please flick an E-mail through to [email protected] and I will send it over once more.
For now, JOC has taken a bow down out of the scene.
We have no relation to JHC and wish them the best of luck. JOC obviously got the ball rolling for something a lot bigger and I wish JHC and those running it the best of luck.
Regards,
JOC.
  • Like 1
Hi All ,
Regards,
JOC.
Ugh it shits me when the good guys lose. Let's hope it's only losing the battle rather than the war. Many thanks for all your efforts, JOC.
sh1t got real
Not to worry...
Some ppl are thinking smarter rather than wk harder - probably on both sides of the ethical fence.
A different band of honest to goodness ppl are having a look at this today (as well as those who've already given support right here on SAU). :yes:
Thanks JOC, you started an invaluable service.
It's a shame that so many authorities turn a blind eye to what essentially is a criminal act of international proportions! That's exactly where the problem lies I think. It's too hard to prosecute for what is considered to be a lower end of the scale crime. When it is done on a large scale though, that's the game changer!
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
