The 6258 is more suited to a 2ltr or smaller. I have a 6758 on my 2ltr Wrx and you wouldn't want anymore response. We have a 6758 .8A/R on a c34 Neo Stagea making 20psi by 2500rpm.
Excuse my ignorance and lack of knowledge. Would that mean running out of high end puff but having everything down low? I only ask as ive asked a highflow service provider if i can get bucket of low down torque and power to suit my driving style in tight and twisty roads not interested in long straights and high kw. And well said service provider sent me to a factory replacement turbo running same boost and comes on at around same time... sorry for long winded question hope you can pick it out i think ive even lost it in there somewhere
You will certainly have response with the 6258...the starter motor will bring it on boost. You will have positive pressure from idle. It's Still no slouch. Have seen a time attack car win several events with the 6258. Only problem is you make risk over spinning the turbine up top to keep the flow from dropping off...which causes other things to drop off ;-)
Edited by BoostdR
Cheers for the info mate. Well that puts a downer in my plans.
It will still be awesome, will just be limited to 20-25 psi up top due to the pumping capacity of the 2.5. If you're get onto Borg Warner match bot. It will plot your wheel speed. Check the speed limit on the associated flow chart.
Here you go, I've done it for you. As you can see the little 6258 will over speed ifthe boost is kept up at high rpm. Drops off even more than I thought. These turbos are good for the 2.5 ltr Wrx Sti that only rev to 5500rpm. You would definitely need the .85a/r turbine housing. Check out the boost pressure level in the table.
20psi dropping off (reliable turbo)
20psi holding, .85a/r (over speed)
Edited by BoostdR
Anywhere else such as where the airbox sits is going to limit the dump flow, I would mount it in the stock location, perhaps slightly tilted up at the front to help straighten the piping a little. Shame we can't swap the starter to the other side like the VQ30det.
If the compressor housing is much larger than a GT30 TO4E? I think you will struggle in the stock location, mine only just fit. Apparently there is a GT35 in one somewhere, but damn it must be tight. You would want at least 10-15mm clearance from the chassis rail unless you want to run solid engine mounts.
limit the dump flow?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
