I think both sides (talking globally here; not talking about people in this thread) have an arrogance that pisses each other off.
Cyclists that flaunt themselves on the road, taking liberties just to piss people off, and motorists that think the world revolves around them (ahem mums on the school run....) and nothing should ever get in their way.
Sounds to me like Daleo is a good example of a responsible cyclist, he isn't going to be the one taking up a whole lane on a single lane road, he'll wave you past when it's safe to do so. In turn, and in respect of that, I'd pass him giving him as much room as I safely can. That's all that needs to happen.
  • Like 2
this.
and when I ride, I keep to the opposite side, so I can see on coming traffic.
I ride on the road(when no brake down/bike lanes are available), and move onto the mud/grass/gravel when a car does approach.
I want to see them coming.
that way, I can react accordingly.
I also dont wear a helmet (lets not get into that debate atm), and have never been booked for not.
but...
if I do get booked, my reaction will be taking an entire lane the entire trip.
because, thats the law....
dont ride much anymore, so doubt it will ever happen.
aaand, go...
this.
but...
aaand, go...
How is your crank bearing....?
Here's an interesting article from the US about the "Idaho Stop".
http://www.vox.com/2014/5/9/5691098/why-cyclists-should-be-able-to-roll-through-stop-signs-and-ride
It proposes some constructive solutions for getting bicycles off high traffic thoroughfares, which would be a win for both sides of the argument.
Not trying to inflame the situation, but there is some useful info in there, and the rule (or a version of it under a different name) has been in use in states across the US with fewer negative outcomes than the status quo.
Yeah, apparently cars are exempt from the laws of physics. Spot that line in there?
Frankly, I didn't think it was a very well written article, and it didn't sway my opinion that it is safer to have enforced stop and red lights.
If governments were serious about reducing carbon emissions, they wouldn't be installing traffic calming devices, red lights etc etc all the time. Imagine the carbon footprint of a new set of traffic lights over its lifetime?!
But that's ok, cause the government gets the cash from the fuel excise.... :/
Did you see the main point in there? Bicycles don't trigger the light circuit, so the lights will never change. I am sure many of the motorcyclists amongst us have blown a red for that very reason. I know I have had to many times over the years. Does this make me a criminal worthy of being stoned with spark plugs? Farkin wanker...
"Several states have similar "Dead Red" laws, which lets cyclists (and motorcyclists) ride through a red light if there's no traffic, if the cyclists have stopped for set periods of time, and if the light isn't changing because its sensor doesn't register bikes."
Yes, I can see that, after stopping for a set amount of time, the cyclist can proceed through the intersection. They might also be able to use that magical button on the side of most traffic lights that turns them red to allow people to cross... ;)
Anyway, thanks, when did I ever say I chuck plugs at cyclists....? I thought my posts were pretty neutral....
Wanker comment was directed at the bloke suggesting it.
Cyclists aren't allowed on the footpath, and quite often are clipped into their pedals. Magical button? It's for pedestrians. Yet again, there are no facilities for cyclists in most cases. These would need to be included in any bike rego process.
Carry a broom stick to push said button? :P
Then you can bash arsehole drivers who try to clip you, and also have a jousting session when you get to two lane bike paths! :D
  • Like 2
Bicycle jousting is the best solution this thread has produced.
Nice work Luke!
Brb, off to get a broomstick.
It wasn't saying that cars expend no energy to get moving from a standstill, just that the driver isn't the one physically getting the car moving again; unlike the bicycle.
Nice work Luke!
twasnt my idea, but I like it.
You shall be forced to mount the toddler tricycle for the first round of bicycle jousting.
Mmm K?
Nay, I shall be astride the toddlers balance bike.
Yea verily; it has newfangled yellow plastic wheels, and an ooga horn.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
