Cheers for organising a great day, so I didn't quite get to grips with the kart in the wet but great fun and so glad I brought a change of clothes.
Crumpled results attached
I'd have attached the racechrono Le Mans Lakeside track but the uploader didn't like the rcz file
SAU Kart Rnd#1.pdf
Was a real fun day, even for those (me) when off the track! :P hope everyone had a blast and got near a heater quick afterwards. Next round in a couple of months so stay tuned for more info on that. Will post up series points later tonight for people to either boast or cry over :)
Zip it, or rename the extension to pdf, then we can download it and rename it back to rcz
racechrono Le Mans Lakeside track zip as requested included a couple of splits.
With the rain, had no idea where the start/finish was.
track_le_mans_1.zip
Ok so points after round 1 are -
Quinton R - 25pts
Sam C - 18pts
John R - 15pts
Ray B - 12pts
Rhys S - 10pts
John P - 8pts
Andrew C - 6pts
Simon H - 4pts
Sean P - 2pts
Tony O - 1pts
Michael K - 0pts
Robyn R - 0pts
Guest
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
