Thanks mate!
No specific plans to be honest. Just a few things I'd like to do.
So, after the trackday I went over everything again. Found my gearbox was making a nasty input bearing noise, so took it down to award. After a chat to Terry, he said it was nothing to worry about, and that the noise would probably drive out in a few hundred kms on the road. I suspect the ATF I was using in the box was too thin and not providing enough protection in high G areas, so I refilled it with Redline Shockproof light. Again, I can't complement the gearbox enough. People say they are weak, but this has had so many track days now, and looking back on the vids, a couple of times where it should have gone pop but hasn't! Driving style has a lot to do with it I think.
I've installed a power steering cooler, as I think the PS was getting pretty hot. I grabbed a small PWR auto tranny core from repco and plumbed it in, and ran a duct to it. Pics will be below. Pretty easy to setup, and not very expensive. It's just mounting it and finding the space!
I've got to get the dump pipe off, and it's got a couple of small cracks on one of the supports, they need a bit of weld.
I want to investigate water cooling for the wastegate. It has a tial 44mm on it, with the ports to water cool it. I want to do this mainly for reliability. But I'm not quite sure where to get and return the feeds to.
I also want to make up some deflectors for the front brakes, as they were getting pretty damm hot and glazed the pads. I never lost brakes, but it is clear that they can work better then what they were.
Finally, I might have my hands on some more slicks to try out after the Sydney 500. Should be a set of Yokos I can get my hands on. The Michelins have been epic, and are the Rolls Royce of slicks, but they are getting pretty worn now (have a look at the front right!).
  • Like 1
  • 2 months later...
You'll shit in an 11 if you can get it off the line.
Probably, my best 60ft was a 2.0
It's a bit of a pig to get off the line. This is on federal RSR 235/45/17 at 25psi. Doubt I'll take it again, I just don't want to smash the gearbox.
That brake squeal though
Because Racecar! Actually, I was bedding brakes in down the slow down area :D
  • Like 1
  • 1 month later...
Trackday put on by RTDC at SMSP south circuit. Had unfinished business since I was unable to take my place at the 2014 SAU trackday.
Had a little hiccup where some silicone intercooler pipe decided to burst due to heat and pressure, but fortunately some guys at the track helped me out with leads, and after a short drive, it was back in business without missing a session. Will make up some heat shielding to protect it for the future.
Rear tyres turned out to be pretty diabolical, so I couldn't even get full boost into her. Definitely due a new old set of slicks. In comparison, on full power out of the hairpin on the Brabham circuit day I could get power down pretty easily. On low boost it just burst into wheelspin.
Nevertheless, I got a PB (by 3.5 seconds no less!) of 1:04.1. Have no doubt on some fresher tyres that would drop into the threes.
  • Like 2
I heard the dyno ate your next pair of slicks, and the set from the F1GP will be mine... suckah.
Lol, no, someone who wanted to put on a "good show" for the cameras cause his ugly mug is gunna be on the telly ate up my new pair of slicks down to the belts!
I'll have my grubby little hands on something... ;)
  • Like 1
  • 3 months later...
Well, long time since updates, so away we go!
I noticed the rear pads were getting pretty hot, so I did something I should have done a long time ago. Cut the stone guards off it. I know, exciting right!
On to better shit.
I wanted to get it looking a bit tougher, and I went through a phase of looking for Type X bits for ages, but never bothered getting anything. I liked the look (everyone does compared to the earlier front end!!) and it gives me heaps more air to play with for ducting. Well, I found a OEM front bar, AND an OEM Lower lip for sale round my neck of the woods. Went for a drive, cash changed hands and boom; it was mine :)
Needed a bit of work, had some random holes in it, bit of a ding, and was silver, but had all the metal to go behind it. Well, something to work on!
So, I went to work - fibreglassed the holes, and a crack in the lower lip. Bogged up the dent, and filled the holes,
More to come in a bit :)
  • Like 1
So being an hugely experienced painter (having painted two bars, and a roof in my life...) I decided to do me own work. DIY mechanical is one thing, paint and panel is totally another!
Anyway, Bar and lip went into primer just fine
And then all these bits came along to make it look a bit more complete.
They're from JSAI Aero, and seem to be of decent quality, and test fitted ok.
Finally, a bit of a sneak peak ;)
Still have a fair bit more paint work to do, so another couple of weekends probably before its time to roll.
Got to get the electronics sorted for the new indicators too. The LEDs need resistors, and the wiring needs a tidy up.
  • Like 3
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
