Car was running fine, then decided to finally coat the caps on top of the injectors, put them all back, new stainless bolts and now black caps and its running rough.
ive narrowed it down to no6, as when removing injector plugs one by one its only one that does not kill or affect the rough idle, it has 11.72v to the plug.
How do i check the injector is firing?
Why would it now not be working after a simple take cap off paint replace bolts and reassemble?
I did at the same time take off cas and timing belt cover to paint exposed vct end as it now shows through the rb26 timing cover, but this idle is way rougher than just the cas being a smidge out and changing the cas position makes little to no dif, i had marked the cas up before removing its always been marked as it gets removed occasionally for various things...
Any help appreciated
https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/
Ok ive confirmed its not the injectors, swapped a couple around and still same issue.
Checked plugs, one was sooty the other was wet, changed plugs, still same issue,
Thought perhaps painting the vct end of the cam has done something, loosened four small bolts on front of vct and had a look tightened them back up car is running much better but still a bit rough.
So, what do people think has happened, painting the vct has caused it to not work correctly.
I did notice the exhaust sounded weird when running rough and atmo bov noise sounded different now that i loosened the bolts on vct and tightened them again sound is back to normal beside it still running rough..
Ive got rb26 cam and timing belt covers, i cut a hole in the timing belt cover to allow the vct intake cam end to poke thru, since ive be dressing up the engine bay ive pajnted case and now the intake cam end, which is the vct actuator (not sure what to call that), so i painted the part that pikes thru the 26 timing belt cover for cosmetics, but it seems in doing that it may of created this prob.
Ive only noticed it as i painted it around the dame period as painting the caps on the injectors, it doesnt get driven much..
So when ive loosen and retighten the four bolts on the the end of the intake came, vct end part it has made a difference to the rough idle..
Hence why i thinking painting it has interfered with its operation, are the four bolts on the the end of the intake cam (vct) needing to be to torqued to a specific number or are you not supposed to loosen and retighten them at all...
This is something ive not done previously so im shooting in the dark here...
Your help is much appreciated...
Yes I agree with above^^^^^
Please send photo of engine bay. do you think you might have painted a contact for one of the injector power supply. Next did you remove the vtc timing sprocket to paint it. ??:huh::huh:
Looking at it I doubt that's the issue but as it only happened after you painted it must be, all I would do is grind the paint off under the bolt heads just incase it's some weird earthing issue and change back to mild steel bolts instead of stainless . I had an issue like this years ago with an audi and it's hard to accept sometimes but the issue wasn't there before so you have to start again unfortunately
I'm using stainless bolts on my side feed injector caps, no issues at all
As for the VCT actuator which you have painted, It shouldn't really effect the performance of the car at all wether you painted it on the car or off. By the looks of it you painted it off the car, but I could be wrong. That bit there is all mechanical, the only problem you could have would be oil leaking from the front cover.
Seems odd that Something happened when you played with that cover. Maybe there is a problem with the VCT somewhere, maybe in the solenoid or wiring. Have you tried unplugging the VCT and seeing how the car runs? I get the feeling you might have already mentioned that you have done this but just in case
What ECU are you running/whens the last time it was tuned?
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
