can the team motto be
"Super Fun Happy Sliders"
which the closest japanese translation i can get is 極度な楽しみの幸せなスライダー
which when translated again = The extreme it is pleasant straw raincoat happy slider
  • Replies 120
me? I'm part of the mill park massif (including Roy, skylinegeoff, doxx and a few others)
.... its all good except the dress they make me wear :)
Team Trackday? Me wants in:wavey:
... me too, do i need vic rego, or can any hillbilly from a northen state play :hippy:
perhaps if u explained urself a little better as to what exactly it is that you were refering too we migh be able to be a little more helpful.
read the previous posts as there are a few questions which werent answered in regards to your question.
ie. this is a car club? were you refering to a drift team? a togue (sp?) team etc etc etc
Roy: yeah your probably right, i can't drive for sht so i doubt anything bad will happen, but just paranoid i guess incase i get lucky or unlucky...
Gojira: what do you mean oil supply up to track work?
Well the stock sump is nothing special especially if you are pulling some lateral G's with sticky tyres and roly poly stock suspension, I have heard that simply overfilling the oil by a litre is enough. But ideally a baffled sump and an oil cooler is some good protection.
I think the stock pump is fine on RB26 using std revs, i think it more to do with the fact that there is no oil around the pick up during sustained cornering, so the pump is always going to struggle so pump what isnt there. I think th epump is only an issue if you are usign higher then std revs, or the thing is shot to start with
i should rename this thread to FERNI's TRACK NEED- Needs HELP!
nawwww... jk
well im thinking of a drifting/racing/car cruise club sorta thing...
it was be tastey to see a mix breed of cars not only skylines.
if this can be done i have some people with silvia's and seven's lineing up and atm i just need some SAU peeepz in it!
thanks
There are some pretty well established non car specific clubs.
MCCR, Exclusive, TeamAZM, Fangartists etc...
One of those or a subgroup of them should suit your needs.
(If anyone is "ex" one of those clubs save your biatching for MSN)
But I will always be a Super Fun Happy Slider
...well im thinking of a drifting/racing/car cruise club sorta thing...
There isnt a name for it except a few folk going for a boring 3 hr drive, so to enjoy 6hrs of thrashing around at highly illegal speeds which must be reserved for these sorts of occasions...come one, come all.... :(
See Here
I dont really know any Vic guys (except for those poor few who havent been able to avoid me:Oops: ), so not knowing anyone isnt an excuse, actually its the perfect reason to come along, get to meet everybody and enjoy our cars :D
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
