Which ever style of these cars you prefer are both good choices. If you haven't had an evo or similar before you should try one out.
You'll find that the evo is quick around town etc but there's a lot of very quick evos & gtrs that are quicker
Breasts is an easier choice for sure!
Seems like it's been on your mind a while?
http://www.skylinesaustralia.com/forums/topic/365045-r34gtt-vs-evo78/
Give one a go, or wind the 34 up to 350ish ;)
My 2c. I have both cars and prefer the skyline.
The evo with less power is a few seconds faster than my skyline around a track.
The evo has superior response and acceleration, but the feel (steering/chassis) isn't as good as the skyline (I'd say less honest with all the electrics).
I find the skyline more enjoyable on the street (love engine/exhaust noise, better interior, slowish/deliberate long throw gearshifts, non-stiff suspension).
The skyline requires more effort to punt around a track quickly and I appreciate that aspect, along with watching better drivers drive rwd skylines quickly!
I noticed the factory diff always spin one wheel much harder then the other on take off just like in the clip. Happens to mine as well, Its alright once in third. Rolling start might give the skyline a better chance of winning.
Yes you can go past GTRs because GTSTs and Evos are easier and cheaper to work on . If you are rich and pay people to work on them GTRs are fine , they lack cubes for their mass buts that's life .
Better feel and balance in a GTST/GTt than an Evo in good nic , no way in hell . Far more feel in an Evo 6 GSR steering handling braking wise that a GTS25T , I have both and they both have Pilot Sport Rubber (PS3 Evo) (PS2/PSS R33) . Both have light 17x8.5 wheels , the 33 has the full SK Bilstein kit and the 6 has Whiteline bars and Evo 9 rear Bilstein struts .
Evos are closer to GTRs than GTST/GTT package wise with less comfort and excluding outright power/speed probably better than a GTR in the twisties . Driven wheels grip better than "idlers" and Skylines have a large portion of their engine out past the front wheels . Aside from the lack of FrWd that's why M3s tended to be better handling straight six performance cars than Skylines . Look how far back the engine is in relation to the front wheels , and how much closer to 50/50 weight distribution they have front to rear .
GTR isn't as bad as the original Audi Quatros were but they were both the result of fitting 4WD into an originally RWD or FrWd platform .
Evos are pretty much the same as Lancers back to the front doors except the floor pan from that point is totally different . Ralliart designed that not MHI , up to E6 anyway , so they had lots of freedoms with rear driveline suspension brakes wheels etc .
The thing to remember is that Evo was designed to be a Tarmac Rally basis where Skylines were open road touring cars - GT . It takes something special to be agile and sharp on slippery constantly changing surfaces and they live to be thrown around with everything spinning ALL the time . I was in my mid 20s when GMS raced R32s in Grp A and I don't remember seeing them spinning all 4 most of the time . I do remember them looking smaller and more nimble than the V8 powered taxis and Sierras were really the only serious opposition . Also it wasn't always wet and slicks are the gun thing in the dry .
If you had the same tyres and tarmac suspension , and the same power with equal top speed gearing a GTR probably isn't any better than an Evo , possibly on a fast circuit because of its extra capacity but on one with hairpins and S bends my monies on the Evo .
IMO for dedicated drag race a tubbed RWD is the go .
A RWD Skyline if you punch it everywhere would better suit the "skid/drift brigade" than an Evo because at the same speeds the Evo does more easily and neatly . I guess it's this trying to find limits that some people like . They are higher in Evo and GTR which means going faster to find them - way way faster than speed limits allow and I say again when you lose it at that kind of pace the crashes are often monumental .
You often hear people say AWD cars like Evos are so easy to drive that they make a mug look good . The reality is they get out of shape at higher cornering speeds and when they do they are harder to recover so no the technology doesn't automatically save a goose from themselves .
A .
  • Like 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
