long story short, my turbo timer decided to switch itself back on without my knowledge.
moving the car around the throttle stuck wide open as id just popped it out of gear, so when i killed the ignition the bloody turbo timer kept it going.
looks like oil pressure dropped when it was revving nice & hard, & we all know what happens then.
motor still runs, but it makes nasty noises so ive taken to pushing it from 1 place to another to work on it. the last 2 butterflies are still being wedged open by something, im assuming inside the plenum as i cant locate any issues outside. when i disconnected the link to the main throttle assembly the rest snapped closed, so the issue is definitely in the rear 2 butterflies somewhere. il assess it when i strip it all down to clean & check.
shit go, but id just discovered it needed new gaskets & other stuff anyway....still, not the bill i was planning on.
now you guys get to read a longer build thread once its done lol :cheers:
  • 4 months later...
  • 3 months later...
bit of progress stripping everything apart, now i have bits everywhere.
once i get a good block prepped along with the r33 crank, the build shall begin
added some new wheels as well, aiming for better traction when it's running again
  • 10 months later...
ok so more detailed update after much time absent from the build thread
found the cause of the throttle sticking open....some little japanese bastard shoved a shirt in the intake that nobody ever saw, even after checking on 5 separate occasions prior to connecting cooler piping. i say some little japanese bastard because there's no way humanly possible either fatz or myself could fit in this tiny excuse for a shirt lol
fitted the 18" rims with wider rears aiming for better traction once the beast is running again
retrofitted an r32 GTR 320kp/h speedo to my already retrofitted gtr cluster
picked up an rb26/30 with the intention fitting the entire motor in place of my old sick rb26, but now thinking il just use the head which has been freshened up with 270 degree cams & several other good bits & pieces, then save the 3 litre bottom end to use with the original rb26 head for my cefiro when i get around to starting that (too many projects at once).
picked up some schmick flashy hks cam gears to help dial in the 270 degree cams when the rb26 is alive again too
also fitted a pair of turbosmart BOV's while things are all in pieces
1 last addition, not really noticeable with everything fitted to a motor, but the new turbos are now HKS 2530 items rather than the N1's, il probably keep them & rebuild them for an RB26/30 motor for the cefiro later in life
cheers
  • 4 weeks later...
here's the cefiro for the moment before work begins. initially il probably freshen up the old rb20 from my skyline & get it back on the road with that, while i build the 26/30 for a transplant at a later date. it's an ex drifter so probably got a few things to change for road use
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
