SAU-Vic Member.
Please confirm your attendance (either racing or spectator) so I can sort out catering requirements for the Squires Loft Nunawading BBQ! https://www.facebook.com/SquiresNunawading?ref=hl
Usual cheese/steak sambo's & skewers will be on the menu :)
In this time for this for sure.
SAU-Vic Member.
In for spectating and doing photo coverage for the day.
SAU-Vic Member.
I'm in!
Does anyone know the numbering of the garages well?
What is a rough number which is 2/3 of the way along when heading away from the tower? We've got enough people entering that we could book out 5-6 easily...
Once we've got a rough garage number I'll call up Brendan and book one for SAUVIC / BBQ / Home Base, then post it in here for others to book the surrounding garages.
I usually go as close to garage 10 as possible (starts @ #1 furthest away from the track entry) - keeps you away from the staging area mayhem.
Most SAU'ers were down the other end to me last track day so there may be a preference?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
