You do a great job with the SAU social media side Christian, and I would gladly contribute here, as I did the FB thread, but there is already an R32 photo thread and I think excluding other 32's would be somewhat elitist.
  • Like 1
We seem to have this 'one thread to rule them all' mentality these days. We're not running out of threads, we can make more.
And, if it makes you feel better, we can create a gunmetal, silver, blue, black and an 'others' thread too. :D:thumbsup:
Looks the goods. How much camber on the front?
3.5 degrees. Looks a bit sad because the tyres are only 235/45's not the 255 track rubber.
Lawn is now mowed too.
Oh and WTB some ce28's in a 17x9 +15 or 22 fitment titanium silver?
Edited by djr81
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
